Ignition Switch for '68 Chevelle needed. - Chevelle Tech
 6Likes
post #1 of 24 (permalink) Old Jan 16th, 19, 10:57 PM Thread Starter
I'm in the process of rewiring my car and want to install a new ignition switch while the dash is out. I stopped by my local Chevelle parts store but they did not have a replacement part. I also Goggled it, eBay'd it and no luck. The part number I need is GM #1116703. Any suggestions?
None of the "Replacement" parts come close to fitting snug due to the thread location. You guys are my last resort.
Sent from my SM-G930V using Tapatalk
frank1911 is offline
post #2 of 24 (permalink) Old Jan 16th, 19, 11:11 PM
leo
Re: Ignition Switch for '68 Chevelle needed.
Try this one at your local NAPA store!! https://www.napaonline.com/en/search...tForm-savedveh
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #3 of 24 (permalink) Old Jan 17th, 19, 12:13 AM Thread Starter
Thanks Leo. I will check with Napa.
I forgot to post photos of what I'm looking for. The dark switch (Old) is the one I need and the lighter one (New) is a supposedly direct replacement. You'll notice the threads are not in the same place which is causing all sorts of issues.
post #4 of 24 (permalink) Old Jan 17th, 19, 12:15 AM Thread Starter
Here they are.
post #5 of 24 (permalink) Old Jan 17th, 19, 12:54 AM
I ordered a NOS switch from Ebay for my 68SS. The reason I did that was because the new replacement switch I ordered shorted immediately (thank God for a fusible link). The switch was made in Mexico. I can't remember what I paid for the NOS switch but I think it was around $70.
billbonn80 is online now
post #6 of 24 (permalink) Old Jan 17th, 19, 1:24 AM Thread Starter
Thanks Bill,
I would love to find one on eBay. Let me know if you see GM #GM 1116703. Thanks!
post #7 of 24 (permalink) Old Jan 17th, 19, 1:45 AM
Thanks Bill,
Are you sure that is the correct number? I don't have my assembly manual in front of me but for my 68SS it is a different number(1116694, D1426A). I just saw one on Ebay for $30 that is supposedly NOS.
post #8 of 24 (permalink) Old Jan 17th, 19, 8:39 AM
Jon N.
Here they are.
There is a number on switches that is usually either stamped in, or cast in, in a small oval.
What is that number on your original?
dyno jonn is offline
post #9 of 24 (permalink) Old Jan 17th, 19, 10:00 AM
Owning a 68 I must admit I'm am very confused about this discussion. I ordered a new ignition bezel, ac delco ignition switch and new wiring harness and no one or seller mentioned there were two types in 68. I can see from your picture the harness plug itself would be different and M&H did not ask me what type I had. Everything was plug and play. What am i missing?
Billdini is offline
post #10 of 24 (permalink) Old Jan 17th, 19, 10:17 AM Thread Starter
There are two sets of stampings. They are 703 on one side and 13 on the other side.
post #11 of 24 (permalink) Old Jan 17th, 19, 10:30 AM Thread Starter
Bill,
Actually the harness part is fine. It plugs right in. The problem is at the threads. The new one bottoms out too soon but acts as if it's not completely seated.. This causes the ignition to still be loose while completely seated.
post #12 of 24 (permalink) Old Jan 17th, 19, 10:42 AM
Did your original work? I have a used one for sale, if that would help.
RealRed70 is offline
post #13 of 24 (permalink) Old Jan 17th, 19, 11:04 AM
Jon N.
There seems to be a few inconsistencies between my GM/Chevrolet/Delco parts books, even in the ones I have that were printed in 1968. One catalogue shows 1116694/D1426A, and the other shows 1116703/D1400A. Both are Delco/GM parts books and both were printed in 1968. My Chevrolet parts books show the 1116694 being correct, but that's the one that doesn't work for you. If the 703 works, go with that one. You can also search ebay for Delco part number D1400A, that's the short number for 1116703. Doesn't do you much good, but a new D1400A sold on ebay a couple of days ago for 24.95, and it matched your picture exactly. Search using both numbers, because the one that just sold didn't have the long number listed, just the short one. Good luck.
post #14 of 24 (permalink) Old Jan 17th, 19, 11:31 AM Thread Starter
Thanks Dan. Yes my original still works, but since the dash was off and all the other wiring is new, I figured now was a good time to change it. I'm actually glad I found this out now instead of waiting till I actually needed one. You never know, I just may DM you in the future.
post #15 of 24 (permalink) Old Jan 17th, 19, 11:32 AM Thread Starter
I'm sure.
