Ignition Switch for '68 Chevelle needed. - Page 2 - Chevelle Tech
 6Likes
post #16 of 23 (permalink) Old Jan 17th, 19, 11:35 AM Thread Starter
Re: Ignition Switch for '68 Chevelle needed.
Originally Posted by dyno jonn View Post
There seems to be a few inconsistencies between my GM/Chevrolet/Delco parts books, even in the ones I have that were printed in 1968. One catalogue shows 1116694/D1426A, and the other shows 1116703/D1400A. Both are Delco/GM parts books and both were printed in 1968. My Chevrolet parts books show the 1116694 being correct, but that's the one that doesn't work for you. If the 703 works, go with that one. You can also search ebay for Delco part number D1400A, that's the short number for 1116703. Doesn't do you much good, but a new D1400A sold on ebay a couple of days ago for 24.95, and it matched your picture exactly. Search using both numbers, because the one that just sold didn't have the long number listed, just the short one. Good luck.
THANK YOU!!!! This gives me hope.
Sent from my SM-G930V using Tapatalk
frank1911 is offline
post #17 of 23 (permalink) Old Jan 17th, 19, 12:37 PM
Originally Posted by frank1911 View Post
Thanks Dan. Yes my original still works, but since the dash was off and all the other wiring is new, I figured now was a good time to change it. I'm actually glad I found this out now instead of waiting till I actually needed one. You never know, I just may DM you in the future.
That post sure brings back memories. I changed out my ignition switch just because I had the instrument bezel out and the original switch was going on 50 years old. Once it was back in the new switch shorted out so installed the old original back in the bezel. I changed it with the bezel installed which actually wasn't that hard. The NOS I ordered off Ebay is still not installed but I think it is getting installed soon but now I know I can pull the front bucket seat and get to it.
I hope you find your switch and if I see one I'll let you know.
Bill B.
davewho1 and frank1911 like this.
billbonn80 is offline
post #18 of 23 (permalink) Old Jan 17th, 19, 1:23 PM
Someone else on here recently had the exact same problem. Lemme see if I can dig up that thread, I can't remember the resolution.
frank1911 likes this.
Scott W.
Electrical Engineer
700R4
This is how we roll:
red68chevL is offline
post #19 of 23 (permalink) Old Jan 17th, 19, 7:39 PM
Greg
RE the two switches in the pix: The new one is correct for a '68. Can't say that the old one was never used in a '68.
Greg
My 68
and my 68
. In 1968 I got my
66 Chevelle SS. 30 years later, I got my
. Both Chevelles are in the same location.
Greg P is offline
post #20 of 23 (permalink) Old Jan 17th, 19, 9:02 PM
I just checked my assembly manual and the only call out I can see for a 68 ignition switch is 1116694. Please correct me if I'm wrong. I just wonder if the ignition switch you took out is not correct. If it was me and based on the assembly manual I think I'd get a 694 switch. And based on my experience with an after market switch, I'd pay a few dollars more and get NOS. Hope this is helpful for you.
Bill B.
post #21 of 23 (permalink) Old Jan 17th, 19, 9:48 PM Thread Starter
Bill B.
Hi Bill
It is the factory switch (1 owner car). After some research it would appear the Auto Workers Union went on strike against GM back in 1968. It's my understanding it is not uncommon to find other model GM vehicle parts on different models (e.g. Pontiac seats in a Chevy car, etc.). It does appear GM used both style ignitions in '68. Bummer for me.
My search will continue and with the community's help, I'm confident I will find one that works for me. Thank you,
Frank
post #22 of 23 (permalink) Old Jan 18th, 19, 2:02 AM
Hi Frank I do remember back away"s that you did have to match your metal insert that screws into the new chrome plastic threaded bezel. I did not have to do to do that and I just removed my old metal insert that screwed into my old plastic chrome bezel (fine threaded) and threaded into my new threaded ignition chrome surround. I was good to go after that and nothing is loose and the ignition key is oriented correctly using a new white ignition switch. In either case I think you need the correct metal insert for your ignition bezel allowing you to use the new new switches making your life easier although I have never had to replace an ignition switch over the years. Best of luck!
Billdini is offline
post #23 of 23 (permalink) Old Jan 18th, 19, 3:04 AM Thread Starter
I will definitely take a look at my bezel and compare it to a new one. That just may make the difference. Thanks Bill.
LeoP likes this.
