Does anyone know of a wiring harness rebuild service? - Page 2 - Chevelle Tech
 16Likes
post #16 of 21 (permalink) Old Jan 10th, 19, 3:58 PM
Greg.
Re: Does anyone know of a wiring harness rebuild service?
Originally Posted by Iggycat2014 View Post
The reason why I'm looking for a rebuild service versus purchase (new) is strictly cost. I am performing a full frame off on my 68 and the costs are already stratospheric.
Only trying to save a little money.
The harness on my Chevelle is salvageable and replacementment dash harness costs are roughly $500/550. If I could rebuild the current harness for half that, I'm ahead of the game. The harness would be restored and tested when I get it back, and I could bolt it back into a freshly painted body as part of assembly. Mike
I do not understand, if you are going to the trouble/work of doing a Frame Off,
why would you put 50 year old Wiring/Sockets back into it,
if a Fire happens after the old wiring/sockets are put back in then you have lost everything !
Compared to a AAW New Complete Harness
A. https://www.americanautowire.com/sho...-1969-chevelle $ 609.us
B. https://www.americanautowire.com/sho...nel-wiring-kit $ 489.us
C. https://www.americanautowire.com/sho...ies-wiring-kit $ 439.us
Originally Posted by 1966_L78 View Post
I just checked again... M&H and Lectric Limited use the same part numbers, and together with AAW, they all have the same prices, to the penny...
I looked at harnesses for my car (1966, 396, gauges no A/C)...
Dash Harness:
LL #09460 $429.00
MH #09460 $429.00
AAW #CH67027 $429.00
Engine harness:
LL #10430 $108.00
MH #10430 $108.00
AAW #CH60430 $108.00
"SE Breakerless" ignition:
All 3 use part #38131 $169.00
AAW out of New Jersey
LL out of Illinois (says their production facilities are outside Chicago)
MH Southern California...
I chose AAW because Donny was on here a lot, and very helpful... Yes AAW had excellent customer service...
So that adds up to $ 706.us if you buy them separately !
Why not buy the $ 100.us less complete one
is it not a complete Harness ??
69SHEVL likes this.
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #17 of 21 (permalink) Old Jan 10th, 19, 9:46 PM
Looking for a wiring harness rebuild service, preferably in the Northeast.
Are there problems with the harness? Are you changing lots of things electrically? I usually rebuild my own. Connectors are easily sourced if you know what they are called. Good wire is also available....
gnicholson likes this.
Scott W.
Electrical Engineer
700R4
This is how we roll:
red68chevL is offline
post #18 of 21 (permalink) Old Jan 11th, 19, 3:22 PM
Actually not $706... The $169 mentioned was a breakerless ignition system (like a Pertronix conversion), I was just noting how all 3 of these companies offer the same parts (often the same part # for the same price..). But yes, its more expensive overall, but its Apples to Oranges comparison.
Its kind of like asking why someone spent thousands of dollars on big wheels/tires, when they could have saved money with 14" or 15"...
No, the $609 harness is NOT really a complete harness... Its a harness KIT and supposedly "complete"... but many of the wires need to be cut to length, terminals crimped (and/or soldered) and terminals installed. It is also NOT stock and not compatible with stock harnesses.
The group of individual harnesses ($706) should be plug and play, EXACT duplicates of the original wiring harnesses. But depending on the extend and options, that $706 can go much higher (Not only "Dash", "Engine", "Forward Lamp" harnesses, but "rear light", "dome light", "Console" and maybe a few other smaller harnesses, depending on what's needed.). But all duplicates of the factory harnesses.
So IF someone is going through the effort for a frame off "restoration" then this would not be a good choice. Now, someone modifying a car, these harnesses maybe be good, maybe even better than the original design (more circuits for stereo, A/C, etc? Modern "blade" fuses)...
Kirk's67SS likes this.
TC #1366
Sold
Sold
1966_L78 is offline
post #19 of 21 (permalink) Old Jan 11th, 19, 7:49 PM
It appears to be complete! From the AAW contents sheet:
USAF Retired (1968-1988)
David Bates is offline
post #20 of 21 (permalink) Old Jan 17th, 19, 9:54 PM
Kev
The OP might try wiringharness.com. the dash harness is usually in better shape than ones under the hood or running under the car.
66sc is offline
post #21 of 21 (permalink) Old Jan 18th, 19, 2:21 AM
I used M&H wiring and absolutely original and totally plug and play. You cant go wrong with these guys. I did all my wiring with them and everything was perfect...
Billdini is online now
This Thread is more than 449 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
