Chevelle sweep dash led conversion - Chevelle Tech
post #1 of 2 (permalink) Old Jan 3rd, 19, 3:00 PM Thread Starter
Last year I changed all the sweep bulbs to led bulbs on my speedometer. They worked for about a few seconds then blow the instrument fuse. And if I put a led bulb in the heater control it doesn’t work at all. Only with a filament bulb? I just wanted to brighten it up a little and I’m in the process of restoring the entire dash assembly, so I’m deciding if I should do it again. Just looking for any thoughts on why the fuse would blow with these. Thanks.
hessz24 is offline
post #2 of 2 (permalink) Old Jan 3rd, 19, 3:46 PM
Re: Chevelle sweep dash led conversion
Try installing the LEDs one at a time. I suspect that one of them is defective and maybe shorted out.
JWagner is offline
This Thread is more than 521 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
