How to wire up multiple accessories to fuse box? - Page 2 - Chevelle Tech
 11Likes
post #16 of 18 (permalink) Old Feb 13th, 19, 12:34 PM
Re: How to wire up multiple accessories to fuse box?
Not laughing here - I did the same exact thing for my under the hood fuse box I created. I just used a different housing - but I had to provide my own wire, relays and fuses and assemble the whole thing too.
Originally Posted by ZZ69chevelle View Post
Y'all will probably laugh, but I used one of these and it does the job well. You have to supply your own wire, relays, and fuses, along assembling the whole thing yourself. It's nothing more than the box and some female blade sta-cons.
https://www.ebay.com/itm/Auto-Car-Fu...S!-1:rk:1:pf:0
1972 Chevelle, 454, 2004r, 3.08
lucifershammer is offline
post #17 of 18 (permalink) Old Feb 13th, 19, 2:00 PM
These are the style fuse boxes you can find in the junkyard cheap complete with wire, relays, fuses, etc. They're also weather sealed. Imports are the best place to look for those as they tend to add on to existing systems. Older GMs had relay banks for e-fans and such.
That fuse box isn't a bad idea, would be a good start for a clean wiring harness.
*Jeff*
LQ4 / T56 Swap Project Thread
Hotwire is offline
post #18 of 18 (permalink) Old Feb 14th, 19, 9:41 AM
Verle
I have used an underhood fuse box from a 1990s Chevrolet pickup when doing late model engine transplants. They are weather sealed, have fuses and relays enough to handle anything you want to add and keep all the new stuff off the original Chevelle wiring.
Be sure to label or make a wiring diagram so you know what fuse and relay controls what.
Verle
Tulsa, Ok
http://i877.photobucket.com/albums/a...e6June2010.jpg
Verle is offline
