Adding a 3rd Brake Light to a '67 - Page 3 - Chevelle Tech
 24Likes
post #31 of 92 (permalink) Old Jan 13th, 19, 12:23 AM
Re: Adding a 3rd Brake Light to a '67
Originally Posted by paul bell View Post
I'd love to be proven wrong. Maybe somebody here will buy one and try it.
Before I installed my interior last year, I put a few wires into the plastic wireway for future stereo use. Ran from the dash to the trunk. I used one of those wires to feed my third light so I don't need to fool with these devices.
Paul, I guess you’ve never heard of a silicon controlled rectifier?
It’s a simple circuit.
But I digress.
As far as simplicity and long-term reliability, the best solution is running a dedicated wire back to the brake lamp switch.
Install a switch meant for an 1986 Monte Carlo for example. The extra contacts will allow for the operation of the 3rd brake lamp properly.
If you simply splice into the factory switch, then you will get unwanted backfeed—activating the 4-way hazards will cause a flashing 3rd brake light—which is against FMVSS rules (which I know know one here probably cares). (Not to be confused with a timed pulsing 3rd brake lamp during initial braking).
Coppertop is offline
post #32 of 92 (permalink) Old Jan 13th, 19, 12:45 AM
Yessir, but a SCR would need a circuit to control it. These "converters" don't require steady power-or even a ground.
I never heard of a third light direct to the brake switch causing a feedback. I'll put an incandescent lamp on mine and see what happens. As I plan to use an LED strip, I'd think feedback would be nil.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #33 of 92 (permalink) Old Jan 13th, 19, 12:29 PM
Paul,
The 3rd brake lamp doesn’t cause the feedback.
The term that really should be used is “backfeed”. If you simply tie the 3rd brake lamp (whether it is an incandescent unit or an LED unit) to the white wire on the brake pedal switch, the moment you activate your 4-way hazards, you have a backfeed of power on the white wire—so your 3rd brake lamp will also be flashing. This is a no-no in the automotive industry.
Also, I think you need to review this published circuit I have attached. This provides 3rd brake lamp operation with no dedicated power or ground connection to said “module”.
But again, for those reading this, your best choice is running a dedicated line back to a more modern brake lamp switch set-up for proper operation.
paul bell likes this.
post #34 of 92 (permalink) Old Jan 13th, 19, 1:14 PM Thread Starter
This is great information, thanks everyone. I'm going to use an '86-'88 Monte Carlo brake ligjt; I think I'll get a corresponding '86 brake light switch to avoid any issues. It sounds like the switch won't care whether I use an incandescent 1156 or an LED bulb.
fr8dog likes this.
Rickles is offline
post #35 of 92 (permalink) Old Jan 13th, 19, 1:26 PM
Hey Rick, is the device from American Technology Components internally wired as the diagram you showed?
How may I help you?
1999 Trans Am-500hp
post #36 of 92 (permalink) Old Jan 13th, 19, 1:37 PM Thread Starter
Sorry, the diagram wasn't mine; I only had the picture with the wiring label. I don't know what's inside.
Rickles is offline
post #37 of 92 (permalink) Old Jan 13th, 19, 3:30 PM
Rick, it looks like the one you posted a pic of is their AT-LC-1 logic and it's been replaced with the AT-LC-4, which has a additional terminal for a ground.
If they're description is accurate, if you have a turn signal on then step on the brakes, it will sense both then latch the third light output to on. It'll latch and hold on the output until BOTH light inputs are off.
In other words, once latched, it'll maintain the third light output even though one input is flashing.
I'm not sure how or what the circuitry is but it's worth a try.
The only slight issue is that if a flashing turn signal is on when you let go of the brake pedal, the third brake light may stay on until the flashing light is off between flashes. This could delay the third brake light from going out for a second or so. This wouldn't bother me.
How may I help you?
1999 Trans Am-500hp
post #38 of 92 (permalink) Old Jan 13th, 19, 3:42 PM Thread Starter
He told me they tried the four-wire one but this three-wire is actually an update to the four-wire. According to him, this three-wire is the one to use for a '67.
Rickles is offline
post #39 of 92 (permalink) Old Jan 13th, 19, 3:51 PM
You gonna order it?
How may I help you?
1999 Trans Am-500hp
post #40 of 92 (permalink) Old Jan 13th, 19, 4:12 PM Thread Starter
I think I'll go with the wire to the brake light switch and get a new one for an '86 Monte.
Rickles is offline
post #41 of 92 (permalink) Old Jan 14th, 19, 7:04 PM
So, where are with this third brake light? I'm interested and have ordered the $6 strip and need to wire it up. The third wire up to the brake light switch, is a 3 wire switch needed or can I piggyback onto the white wire?
USN-SSBN 645-G
boyd66k20 is offline
post #42 of 92 (permalink) Old Jan 14th, 19, 11:02 PM
I won't get to test it until this weekend.
How may I help you?
1999 Trans Am-500hp
post #43 of 92 (permalink) Old Jan 15th, 19, 9:48 AM Thread Starter
Keep us posted, Paul.
Rickles is offline
post #44 of 92 (permalink) Old Jan 25th, 19, 8:24 AM
Well, the led strips just don't seem to look right on a 60's car no matter where you put them. Yes, it would be nice to have more awareness back there. Is the monty third brake light an led type. I would be just as happy with third brake light that doesn't have to be LED. The led seems to pimp the ride out too much. What's the vote count , for or against?
USN-SSBN 645-G
post #45 of 92 (permalink) Old Jan 25th, 19, 8:47 AM
Sorry, I got to my shop a few days ago and forgot to report.
Connected to the orange wire at the brake switch, an incandescent lamp comes on and stays on with the brake pedal pressed. It's unaffected by turn signal use. It flashes when the 4-way flashers are turned on. I like that.
The LED strip works the same as the incandescent. It's not as brilliant as I'd like it to be. I may use two-or a different one.
How may I help you?
1999 Trans Am-500hp
