Fusible Link Wire Question - Chevelle Tech
 3Likes
  • 1 Post By 25C 70
  • 2 Post By Jim Streib
post #1 of 12 (permalink) Old Dec 28th, 18, 2:56 AM Thread Starter
I cannot find any 22 ga. fusible link wire. It's not being made anymore. Can I use normal 22 ga. wire to protect 18 ga. wire? I have flame retardant wrapping I can put around it. My knowledge on this is limited so I appreciate any advice. Thanks and Happy New Year to all.
Bill B.
billbonn80 is offline
post #2 of 12 (permalink) Old Dec 28th, 18, 9:36 AM
Re: Fusible Link Wire Question
DOnt know but still see 14-16 ga links made by Belden Cable avail at the big stores like NAPA.
post #3 of 12 (permalink) Old Dec 28th, 18, 10:13 AM
Could you use an inline fuse holder instead of the fusible link.
25C 70 is offline
post #4 of 12 (permalink) Old Dec 28th, 18, 11:55 AM Thread Starter
Only link I can't get is 22 Ga. I've called numerous suppliers and they say it's not made anymore and the parts houses carry everything but 22 ga.
I've already installed inline fuses in the areas where I need 22 ga. fusible link so I'm protected so this question is for my information though I might take the fuses out if I know it would be ok.
Bill B.
post #5 of 12 (permalink) Old Dec 28th, 18, 1:08 PM
Found a few places where its still available:
https://www.awcwire.com/part.aspx?partname=j156-awg22
Wholesaler but may have connections to a retailer
https://www.whiteproducts.com/fusible-repair.shtml
Summit has 20 gauge fusable links
https://www.summitracing.com/search/...d&N=4294819209
70 El Camino SS 396
68 GTO (Thanks Mom)
06 Silverado
07 SRX
OO52 is offline
post #6 of 12 (permalink) Old Dec 28th, 18, 1:18 PM
You can use a 20ga instead. The difference is 2 amps 5A vs 7A.
oldcutlass is offline
post #7 of 12 (permalink) Old Dec 28th, 18, 1:25 PM Thread Starter
I've contacted all the places you listed. They can't get 22 ga wire anymore.
So, my question still is, can I make 22 ga. fusible link out of ordinary 22 ga. wire if I insulate it correctly?
Bill B.
post #8 of 12 (permalink) Old Dec 28th, 18, 1:55 PM
I'm curious, what circuit are you trying to protect?
Is this to keep a restoration exact as it was built?
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #9 of 12 (permalink) Old Dec 28th, 18, 1:58 PM
Bill B.
Bill,
I bought some bulk fusible link wire a while back to do some testing with and I wonder if you have a short length of let's say 18 gauge fusible link wire, could a few strands of the wire be pulled out to reduce it to a 20 gauge, 22 gauge, or ???.
In other word's let's say the fusible link wire had 15 strands, could let's say 4 strands be pulled out thus reducing the gauge total of the remaining to give it what you need ?. It might involve some math and measuring of the strands.
You got me wondering how tight the strands are to each other and covered in the outside insulator. I may have a project to try this weekend .
billbonn80 and Tophog like this.
Always working on something:
Jim Streib is offline
post #10 of 12 (permalink) Old Dec 28th, 18, 2:33 PM
As I recall, fuseable link wire is copper. 22 gauge is 22 gauge and will burn open when too much current flows regardless of what the wire is called. I think the difference is that actual fuseable link wire has an insulation that contains or snuffs out any burning within thereby preventing it from burning other things around it.
How may I help you?
1999 Trans Am-500hp
post #11 of 12 (permalink) Old Dec 28th, 18, 2:34 PM Thread Starter
I hope I don't get chastised for posting on this forum for a non Chevelle car. In addition to my 68 Chevelle SS I have a 65 Corvette. It has no over current protection at all so I am adding fusible links exactly as they did starting with the 67 Corvette. Adding fusible links is not original to the car but it is a add on for safety that I think is essential. 2 18 ga. wires that go to the ammeter need fusible links and it is not available. I've already added fuses to those wires but would like, if possible, to install fusible links rather than fuse holders.
Bill B.
post #12 of 12 (permalink) Old Dec 28th, 18, 4:43 PM
Take a look at the link below. Good explanation of how the ammeter circuit works and how to protect it.
https://www.chevelles.com/forums/27-...ng-1968-a.html
70 El Camino SS 396
68 GTO (Thanks Mom)
06 Silverado
07 SRX
OO52 is offline
This Thread is more than 421 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
