Factory tach....electronic distributer issue - Chevelle Tech
post #1 of 2 (permalink) Old Nov 15th, 18, 10:40 PM Thread Starter
Hey gang,
I am a new owner of a 1970 Chevelle with round gauges. The factory tach is not working and a column mounted tach has been added. Also added was an electronic distributer. Does anyone know of a filter I can try or some solution if the distributer is causing the factory tach not to work ? Thanks in advance !!!
Mark Leedham is offline
post #2 of 2 (permalink) Old Nov 17th, 18, 8:36 PM
Don
Re: Factory tach....electronic distributer issue
It shouldn't need any filter. I swapped out my points dist for a HEI and connected the factory wiring to the new dist and it worked fine
Don
'72 Malibu Convertible
https://www.chevelles.com/forums/albu...ictureid=23370
TC #4782
Lincoln, Ne
MidLife72 is offline
