Is this horn relay correct for 1972 Chevelle? - Chevelle Tech
post #1 of 16 (permalink) Old Oct 30th, 18, 9:39 AM Thread Starter
Can someone please tell me if this horn relay is correct for my 1972 Chevelle? I believe the part number for this one is GM# 1115889. My firewall only has 1 factory hole for mounting up the horn relay. If this is not correct can someone please tell me the correct part number to search for? On a 72 there is a fused 10g red power wire that runs from the starter up to the horn relay & also there are a couple of wires that are connected at the relay that the relay supplies power to as well. Pictures are attached below...
Thank You in advance!!!
ID:	577754   Click image for larger version
ID:	577756   Click image for larger version
WILD72 is offline
post #2 of 16 (permalink) Old Oct 30th, 18, 10:12 AM
Re: Is this horn relay correct for 1972 Chevelle?
Not exactly correct for a 72 but you CAN make it work.
I'm pretty sure that all of the originals are long gone, in fact I think I bought the last two myself (a gift for a friend)
I don't recall seeing a repro. so I can't say how close to original they are.
The red power wire is a fusible link, don't use a regular piece of wire.
post #3 of 16 (permalink) Old Oct 30th, 18, 10:18 AM Thread Starter
Do you have a picture of a correct original?
WILD72 is offline
post #4 of 16 (permalink) Old Oct 30th, 18, 10:23 AM Thread Starter
I just ran a new 10g red wire with a 14g fusible link wire (Dorman #85620) on the end @ the starter.
WILD72 is offline
post #5 of 16 (permalink) Old Oct 30th, 18, 10:53 AM
I'll see if I can find one in my junk
post #6 of 16 (permalink) Old Oct 30th, 18, 11:43 AM
I did a little search and found a picture that might be correct for a 1972 Chevelle ?.
Jim Streib is online now
post #7 of 16 (permalink) Old Oct 30th, 18, 12:30 PM
that's it
post #8 of 16 (permalink) Old Oct 30th, 18, 12:30 PM Thread Starter
That one looks totally different than the one that I have... while the one that I have "CAN" work. Is there a different one that I "SHOULD" use instead of the one that I have now? The one on my car now, is the one that I posted the pictures of part # 1115889. It works... but I want to know if I should put a different one on there.
WILD72 is offline
post #9 of 16 (permalink) Old Oct 30th, 18, 12:36 PM
It's up to you, do you care if it looks original?
You can get a repro.
https://www.google.com/search?source...31.r1F1_ZUJqQA
post #10 of 16 (permalink) Old Oct 30th, 18, 12:49 PM
The one that Dean shows is an original and the one you have in your first post looks like what is on my 68 Chevy II Nova. Both basically work the same but the original has one less terminal on the underside. This additional terminal on the one in your first picture and like what is on my 68 is for the key buzzer circuit.
For added info on the stud of the relay, this is a junction point for other wires as well as allowing power to get inside the relay. Inside the relay this power is connected to one side of an activation coil and then to a contact point of the relay assembly. On the other end of the activation coil, this goes to one of the terminals on the bottom which then connects to the horn button on the steering wheel. When the horn button is pressed the wire to the horn relay then becomes grounded and energizes the activation coil in the relay and it will click. This click noise is from an arm inside the relay now connecting the power from the stud of the relay to a terminal on the bottom of the relay which then sends power out to the horn(s) and makes them sound (providing they are good and grounded well).
This is an album of the combination horn relay/key buzzer for my 68 Chevy II Nova like what you have in your first picture:
https://www.flickr.com/photos/121766...57653574631828
And how this combination horn relay/key buzzer is wired:
A correct one for a 72 Chevelle would not have the key buzzer portion inside the relay.
post #11 of 16 (permalink) Old Oct 30th, 18, 1:20 PM Thread Starter
I found this part # 3996283 & here is a picture of it. I would prefer to have one that is correct... www.classicindustries.com
has these for $53.00. Is this more along the lines of what I should have on the car? https://www.classicindustries.com/product/3996283.html
lucifershammer likes this.
WILD72 is offline
post #12 of 16 (permalink) Old Oct 30th, 18, 1:38 PM
Yep, that's it and I don't blame you, I would rather have the correct one too.
post #13 of 16 (permalink) Old Oct 30th, 18, 1:54 PM Thread Starter
Thank You!
I just want correct operation with correct parts... Although it works with the one from a 68, I would feel better knowing that I have "THE RIGHT PART" on there. Plus, I dont like the fact that it has the "Key Buzzer" in there & that it shouldn't even be on my car to begin with. Im gonna grab a correct one, put it on & save the 68 one as an emergency back up spare part.
Thanks again guys!
WILD72 is offline
post #14 of 16 (permalink) Old Oct 30th, 18, 2:12 PM Thread Starter
Look at this on eBay
https://rover.ebay.com/rover/0/0/0?m...2F302926782666
I just grabbed this NOS one off of EBAY! YAHOO!
WILD72 is offline
post #15 of 16 (permalink) Old Oct 30th, 18, 4:06 PM
