Bulb Replacement with LEDs? - Page 3 - Chevelle Tech
 23Likes
post #31 of 41 (permalink) Old Oct 19th, 18, 11:59 AM
Re: Bulb Replacement with LEDs?
I am hoping someone will submit a detailed tutorial on LED bulbs for our older cars.
billbonn80 is offline
post #32 of 41 (permalink) Old Oct 19th, 18, 3:20 PM
Claude
Bill, there's no real need for a tutorial… Just replace all the bulbs with led's and chose between putting resistors to prevent turn signal hyperflashing (which I did) or go with an electronic heavy-duty flasher and bingo!.. you're done.
Claude.
billbonn80 and lucifershammer like this.
1971 Chevelle SS
toofastforyou is offline
post #33 of 41 (permalink) Old Oct 19th, 18, 5:23 PM
blm
There is a 3rd choice. Just put regular incandescents in the turn indicators and won't have to do anything. The turn indicators are something I woundnt care if they remained a little dimmer as they can be seen if on or not with regular bulbs. Also as I already mentioned a few people that went with led's and don't have dimming ability say that the high beam indicator is annoying with an led. This is another bulb that an incandescent does fine. The problem is all the other guages. They need led bulbs.
blm is online now
post #34 of 41 (permalink) Old Oct 19th, 18, 5:30 PM
Rich
I don't have any LEDs in the dash of the wagon. When I went with LED tails but still had regular incandescents in the front flashing was fine, but when I put LEDs in the front as well, I had incorrect flashing and had to install an electronic flasher module. Didn't matter what bulbs I had in the indicators in the gauge cluster, the tiny incandescents in the indicators don't provide enough resistance to make things work right without an electronic flasher.
Pat_McNeil likes this.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
post #35 of 41 (permalink) Old Oct 19th, 18, 6:03 PM
Claude.
Thanks Claude. I believe I'm going to do what you did. Can you share which LED bulbs you bought. I want the best as I only want to pull the dash once for this. My Chevelle is a 68SS with the tach option. I could change all the bulbs except the tach with the dash in place since I made the gray bulb wires longer when I had the dash apart a couple of years ago.
post #36 of 41 (permalink) Old Oct 19th, 18, 10:21 PM
Claude
Bill, I bought most of the led's from a local electronics store except for the headlamps. Make yourself a list of what you need and ask them for some correct led replacements. As for what I did for the headlamps, see more detailed explanation in the last section of my previous post (post #11).
Claude.
billbonn80 likes this.
1971 Chevelle SS
post #37 of 41 (permalink) Old Feb 20th, 19, 10:04 PM
Test and Tuner
Hi Rich, Could I trouble you for the correct part number for the LED Flasher Module that I will need to convert my 69 Chevelle turn signal bulbs to LED. Thanks for your time.
'69 Chevelle 416" LSA TONY MAMO TFS Heads and custom Hyd roller cam.
Best 60' so far....1.34
Steve Sharp Turbo 400
Motivational Engineering 3.07 12 bolt rear.
Chris Alston's complete "Auto - Cross" coil-over suspension.
Pat_McNeil is offline
post #38 of 41 (permalink) Old Feb 21st, 19, 8:41 AM
Rich
These are the ones I used on the wagon and my truck.
https://www.speedwaymotors.com/Speed...rong,8393.html
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
post #39 of 41 (permalink) Old Feb 21st, 19, 11:08 AM
All the parts stores around me carry electronic flashers. I know most the counter people don't know much anymore, but there's enough people switching to led lights that they should know exactly what you're wanting if you ask.
Or go down the light/flasher aisle. Look for electronic flasher w/ the 2 blades at 90 degrees and you're done!
Good luck!
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #40 of 41 (permalink) Old Feb 21st, 19, 11:26 AM
Jay
They will if you buy the correct dimmable LEDs. Not all LEDs are dimmable.
Do the LED Bulbs fit the stock Standard Bulb sockets for the dash board lights for a 1970 Chevelle SS?
Jay
1970 Chevelle SS L-34
jjr158 is offline
post #41 of 41 (permalink) Old Feb 22nd, 19, 10:37 PM
Rich
There are scores of LED bulbs out there that fit almost any type of automotive bulb in common use.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
This Thread is more than 399 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
