Interior lights help - Chevelle Tech
 2Likes
  • 2 Post By Dean
post #1 of 3 (permalink) Old Aug 21st, 18, 8:47 AM Thread Starter
Please help! Last night i was taking the back seats out of my 70 Chevelle Malibu, of course i had the doors open while doing so and after I was done my interior lights would not turn off when i shut the doors. I checked the light knob and made sure the dome light was turned to the off position. I ended up just disconnecting the battery for a temporary fix but i need to get this fixed ASAP. Thank you for your help!
Jonas is offline
post #2 of 3 (permalink) Old Aug 21st, 18, 12:35 PM
Rob
Re: Interior lights help
you can check the door light trigger pins and associated wires.
the pins, when depressed or Closed would turn the lights off.
There is one in each door jamb
ROB
69 El Camino
robpp is offline
post #3 of 3 (permalink) Old Aug 21st, 18, 1:48 PM
IF the problem is associated with removing the back seat, you might check to see if maybe the white wire to the light got shorted to ground somehow.
wihaltom and Jonas like this.
This Thread is more than 517 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
