Headlight switch not working - '68? - Chevelle Tech
 2Likes
  • 1 Post By Ark68SS
post #1 of 4 (permalink) Old Aug 5th, 18, 11:53 AM Thread Starter
Just installed my dash with all new switches, and is seems the new headlight switch doesn’t work. Did I miss a grounding strap that went from the dash to the gauge panel or does the switch even need grounding? The 68 switch is such a pain to get to! Any ideas guys?
Djh69 is offline
post #2 of 4 (permalink) Old Aug 5th, 18, 2:13 PM
Re: Headlight switch not working?
No headlights OR dash lights?
The switch itself does need a ground but does not need a ground to turn on the head/tail lights.
Check for power at the dimmer switch
post #3 of 4 (permalink) Old Aug 6th, 18, 1:04 AM
Steamy
Wink Re: Headlight switch not working - '68?
Grounding/mounting plate for wiper and headlight switches, a strap from the plate to the rear of the dash cluster, wire from there to the parking brake bracket for ground.
Is the dimmer switch mounted and wired?
BillL
Name:	Dash ground 01.jpg
ID:	571960   Click image for larger version
Name:	Dash removal 10.jpg
davewho1 likes this.
My Showroom
Ark68SS is offline
post #4 of 4 (permalink) Old Aug 6th, 18, 2:14 AM
Al
Grab a test light see if you have power going in and out of the switch. The grounding of the switch has no effect on the headlights or taillights working.
If you need room to work, pull the front seat so you can do so in more comfort.
LeoP likes this.
DUTCH MAX HEADWORK is offline
This Thread is more than 383 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
