AAW wiring kit '70 chevelle alt wire markings. - Chevelle Tech
 2Likes
  • 1 Post By V1rotate
  • 1 Post By Slick87gn
post #1 of 5 (permalink) Old Jul 31st, 18, 2:17 PM Thread Starter
Installed a AAW kit a while back. Vehicle had 1 wire alternator. I have a brown wire from the junction box that was not clipped. There is no marking on this wire. Is this the wire for the alternator [3 wire ]?? Thanks guys
Slick87gn is offline
post #2 of 5 (permalink) Old Jul 31st, 18, 4:45 PM
Re: AAW wiring kit '70 chevelle alt wire markings.
Doesn't your kit come with a color coded diagram? I believe the brown wire goes to the gen light.
oldcutlass is offline
post #3 of 5 (permalink) Old Jul 31st, 18, 5:28 PM Thread Starter
Yes it did. Just wondered why no printing was on this wire.
post #4 of 5 (permalink) Old Aug 1st, 18, 9:58 AM
I just did an AAW system for my 70.
Is your system an original wire harness or a Classic Update system? Mine is a Classic Update and the brown wire does go from the fuse box to the alternator.
I am using a Tuff Stuff alternator that is supposedly capable of operating as either a one wire or three wire, so I set it up as a three wire using the brown wire from the fuse box, what I noticed was a voltage draw when the engine was not running and the key was off. When I disconnected the plug from the alternator the voltage draw was gone, after speaking with the tech support at AAW, they recommended to just leave the white alternator plug disconnected and run it as one wire setup, which is what I am doing and it seems to work fine
70CHEVELLE396 likes this.
V1rotate is offline
post #5 of 5 (permalink) Old Aug 1st, 18, 11:13 AM Thread Starter
I have the Classic update also with a single wire alt. I guess I will leave it as a single wire. Thanks for the info.
This Thread is more than 502 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
