Right turn signal only... - Chevelle Tech
post #1 of 6 (permalink) Old Jul 30th, 18, 3:10 AM Thread Starter
Tony G
Kind of unique issue. Nothing in past posts specific to my issue. Here's the facts: '64 Elco. Restoration completed with cancelling cam and column harness replaced. Turn signals were working fine until I popped off the steering wheel to replace the spring between the steering wheel and the cancelling cam. Both parking lights work front and rear but the brake light and right turn signal not working front or back. The left signal works fine. I ran extra grounds just in case with no change. So I'm thinking of checking power coming from the turn signal switch harness. Any other ideas....or tests to run. Thanks
'64 SS Coupe, 4 spd Muncie M-20, 12 bolt 3:42, 350sb 9.75:1, Edelbrock RPM top kit with roller cam, EB 600cfm carb.
Weekend driver....
Weekends need to be 4 days long every week.....
Antalamo is offline
post #2 of 6 (permalink) Old Jul 30th, 18, 4:22 AM
does the left signal dim down when you hit the brakes? double check sockets for corrosion. sounds like a grounding issue. dielectric all the connections?
BlakeSixty8 is offline
post #3 of 6 (permalink) Old Jul 31st, 18, 1:59 AM Thread Starter
Tony G
Re: Right turn signal only...
I'll run that check and let you know. Just a pain because it all was working fine before I replaced that spring under the steering wheel. I know just taking off the steering wheel shouldn't have any thing to do with it, but how coincidental.
Weekend driver....
Antalamo is offline
post #4 of 6 (permalink) Old Aug 3rd, 18, 1:53 AM Thread Starter
Tony G
Back on the thread for more suggestions. Here's where I'm at:
Ran grounds everywhere, switch, light sockets, column, etc..
Running lights both sides and left turn signal work fine.
Nothing dims when lights are turned on and activate left signal.
The steering column harness is new
Canceling cam is new
Was on another thread and said to run a fused jumper from a hot to the lower steering column harness blue wire. It should light up the turn signal. That should isolate the issue to somewhere in the column wiring??
I'm just looking for troubleshooting options or some other ways to isolate the problem.
FYI: Both signals worked fine a few weeks back. The only thing I messed with was working on the wiper motor ground strap and hooking up the horns on the firewall.
Weekend driver....
Antalamo is offline
post #5 of 6 (permalink) Old Aug 3rd, 18, 10:02 PM
Probably no coincidence. Brake light power is directed thru the turn signal switch assembly. Any issues with the corresponding “side” set of contacts will disrupt front turn signal and/or rear brake light action.
If you have NO RIGHT side operation, crawl under the dash to where the turn signal column connector is. These are the wires you will focus on.
Start the vehicle.
Don’t unplug any harnesses.
Take a jumper wire and stick in the rear cavity areas of the turn signal harness between the dark blue wire and the purple wire. Did the turn arrow on the dash and front signal magically come to life?
Coppertop is offline
post #6 of 6 (permalink) Old Aug 11th, 18, 10:57 AM Thread Starter
Tony G
After some calls to OPGI Tech Dept and a few other blog searches, I was able to figure it out. Along with Coppertop Joe's idea to juice up the harness which should at minimum make the lights turn on, I was able to figure a few things out. The turn signal switch contacts in the right turn mode were not making a good enough connection. The tiny metal strips in the switch had to be bent a slight so it could make correct contact. Secondly the rear tail light bulb (brand new) had a broken filament which is why the rear was not working and the front turn signal housing grounding was not good. Funny because the front running light worked fine, but not enough ground to allow for brighter turn signal. A combination of 3 issues and some hair pulling to solve the right turn signal problem. All works well now.
Thanks to Don who offered up the steering wheel spring. The spring I was told by a steering column restoration shop said most of the time they are not needed but best if you can install one. I ordered one from Classic Industries but was for a Ford. Almost identical to my Chevelle original but need to be trimmed down 1 coil. All putt together with no issues. Thanks to all who had some great ideas to get this problem solved.
Weekend driver....
Antalamo is offline
Tags
blinker , right turn signal
This Thread is more than 530 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
