Key switch install question. - Chevelle Tech
 3Likes
  • 1 Post By turbobrick
  • 2 Post By sampoerna415
post #1 of 3 (permalink) Old Jul 29th, 18, 5:35 AM Thread Starter
Rame
I just recently received a rebuilt tilt steering column for my 72, it's completely assembled except for the key switch (tumbler). Do I have to pull the lock plate and turn signal to install the key assembly? Or does it just snap into place. Also what is the procedure to install, what position does the key need to be in acc, lock, etc ? Also I haven't fully pulled the old column out yet so any tips would be appreciated. Thanks.
sampoerna415 is offline
post #2 of 3 (permalink) Old Jul 30th, 18, 12:08 PM
Aaron
Re: Key switch install question.
Ď72 should be the snap in retainer type. It would normally install in the off position, but youíll need to confirm that the column itself is in that position. The male portion of the lock cylinder/lock engagement is in the column and needs to be clocked to line up with the lock in the off position. This is all assuming that the new column does not have a lock in it currently.
dyno jonn likes this.
Donuts on your lawn.
turbobrick is offline
post #3 of 3 (permalink) Old Aug 1st, 18, 10:18 PM Thread Starter
Rame
Thanks for the input. It does just snap into place, just had to wiggle it back and forth a little.
LeoP and turbobrick like this.
This Thread is more than 536 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
