Electrical Ground Issue - Starter - Chevelle Tech
 5Likes
post #1 of 37 (permalink) Old Jul 10th, 18, 8:22 AM Thread Starter
Burk
I have a 1972 Chevelle Malibu with a SB 350 that has developed an issue when starting the engine.
Sometimes it turns over fine, other times it does not. When it does not there is not even a click when the key is turned.
When it will not turn over and no click, I jump it from another vehicle, it then turns over like normal.
This leads me to believe that I have a grounding problem. So, I replace the negative battery cable with a new one,
cleaned up the engine block connection and the fender mount connection where the little wire goes that comes out of the negative battery cable. I have not had the same problem again, but, it does hesitate slightly before it does turn over. This makes me think that there is still a grounding issue present. I have not looked at the starter solenoid wiring yet. Which wire on the solenoid is the ground? I welcome other ideas as well.
IceBurk is offline
post #2 of 37 (permalink) Old Jul 10th, 18, 8:37 AM
Re: Electrical Ground Issue - Starter
There is no external ground wire on the solenoid it is internally grounded to the chassis.
Saltherring likes this.
oldcutlass is offline
post #3 of 37 (permalink) Old Jul 10th, 18, 9:38 AM Thread Starter
Burk
I appreciate the quick response. Thanks for the information.
Do you have any suggestions as for where I should troubleshoot next?
IceBurk is offline
post #4 of 37 (permalink) Old Jul 10th, 18, 9:47 AM
Vince
how is the positive cable condition??
voltage @ battery compared to voltage @ starter [both pos, + neg]
VinceS427bb is offline
post #5 of 37 (permalink) Old Jul 10th, 18, 9:54 AM Thread Starter
Burk
The positive battery cable is old. Appears to be okay but it is old. I have not done a voltage check yet.
As I am not good with electricity, how do I check?
IceBurk is offline
post #6 of 37 (permalink) Old Jul 10th, 18, 9:55 AM Thread Starter
Burk
I should add that the battery is new as of last year. I check the battery and it is fully charged.
IceBurk is offline
post #7 of 37 (permalink) Old Jul 10th, 18, 9:57 AM
Intermittent starting issues are a pain in the a__. First check your battery voltage to make sure you have 12.7v. Make sure timing is not overly advanced. Then I would start by cleaning the battery cable lugs and terminals, then inspect, clean, and make sure all the other positive power distribution points are the same. Repair any frayed or greenish looking wire terminal ends. Make sure all starter connections are clean and tight.
If all of the above checks good, next time it does not crank, whack the starter with a BFH while someone holds the ign key in the start position. If it starts rebuild or replace the starter.
post #8 of 37 (permalink) Old Jul 10th, 18, 10:03 AM
Vince
cables can have hidden corrosion under the covering
we are looking for a voltage drop between the battery voltage of about 12.6 volts DC
compared to voltage at the starter on solenoid stud batt. cable is connected to...
the amount of voltage drop can indicate how good or bad the [good looking cable is].
post #9 of 37 (permalink) Old Jul 10th, 18, 10:22 AM Thread Starter
Burk
Thank you Eric and Vince,
In the effort of fixing this issue I have already had the starter rebuilt and a new solenoid installed. Rebuild shop is a good one and they tested after the rebuild.
I installed the starter myself. I cleaned things up at the time but I probably should take another look. After doing these things the problem remained.
I think my next steps will be these. Replace the bolt that attaches the negative battery cable to the engine block. It is a black oxide bolt that is old and does have some corrosion on it. I will not replace it with another black oxide bolt.
I will check for voltage drop to the solenoid positive connection. Wish I had a lift. Also, I may as well buy a new positive battery cable and install that.
Thanks guys!
IceBurk is offline
post #10 of 37 (permalink) Old Jul 10th, 18, 10:37 AM
Levon
Make sure al of the starter bolts an starter wiring nuts are tight. Disconnect the cables from the battery when doing the starter wiring.
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
post #11 of 37 (permalink) Old Jul 10th, 18, 10:47 AM Thread Starter
Burk
Does anyone happen to have a 1972 solenoid wiring diagram they could send me?
Just to make sure I have things correct.
IceBurk is offline
post #12 of 37 (permalink) Old Jul 10th, 18, 11:03 AM Thread Starter
Burk
I should state that years back this engine was converted to HEI.
IceBurk is offline
post #13 of 37 (permalink) Old Jul 10th, 18, 11:05 AM
Dont have a diagram, but it ought be only three wires, BAT, "R" and "S", one being the power to the solenoid(S) and one is straight 12V to ignition to fire it. (R)
That block ground is key. My car wouldnt start the other day, completly dead. It was that bolt in the head being a freckle loose.
EDIT, if you converted to HEI then you dont have a resistor wire in the ignition harness and do not use that R terminal to send 12V hot to the ignition anymore. Thats for "resistance wire" cars that need 12V to fire. So you have the BAT and one terminal from the ignition switch to the solenoid is all.
post #14 of 37 (permalink) Old Jul 10th, 18, 1:34 PM Thread Starter
Burk
Here is a picture of the old solenoid before I replaced it. I wanted to make sure I got the wires in the right spot.
It looks like the brown wire is on terminal "R", the positive batter cable is where it should be but the pic hides the wire on terminal "S".
It has been this way for 25 years. I wonder now as mentioned that when converted to HEI the wire on terminal "R" is no longer needed.
As you can see it is there, what kind of problem will that cause?
IceBurk is offline
post #15 of 37 (permalink) Old Jul 10th, 18, 2:19 PM
none, its likely tucked into the harness somewhere, but I'd hate to guess looking at a keyboard.
