66 radio capacitors how do I check them? - Page 2 - Chevelle Tech
post #16 of 20 (permalink) Old Jul 8th, 18, 9:28 PM
Randy
Re: 66 radio capacitors how do I check them?
Jim, does your AM reception crackle with the engine running or just with the XM transmitter? You can try adding a 3MF capacitor from the feed for the cig lighter to ground to see if you get some improvement. Some of these transmitters are really sensitive to ignition noise. Is the connection from your transmitter to the radio wired with shielded wire? Post the model number of your transmitter, maybe we can glean some info about proper grounding techniques for it.
Randy
TC # 5401
67 Project SS Clone
pnugene is offline
post #17 of 20 (permalink) Old Jul 8th, 18, 9:55 PM
Those 2 caps are for noise suppression. If they were bad you would get a buzzing noise that will change with RPM.
oldcutlass is online now
post #18 of 20 (permalink) Old Jul 9th, 18, 8:31 AM Thread Starter
So you are saying that as I increase the rpms, if I get no bussing noise the capacitors should be good to go?
Jim_66SS is online now
post #19 of 20 (permalink) Old Jul 9th, 18, 8:38 AM Thread Starter
Never tried the AM connection, only the FM, I will try that. I don't think there is a connection from the transmitter to the radio, it just plugs into the cigarette lighter no wires any where. I will post the number of the transmitter along with a photo later today. The feed from ignition to the cigarette light is kind of short and truck way up there under the dash and a difficult access.
post #20 of 20 (permalink) Old Jul 9th, 18, 9:07 AM
Yes.
There is a trim pot that you can adjust/tune. Scroll down to trimmer adjustment.
https://www.chevelles.com/radiotech/reception.html
This Thread is more than 405 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
