Neutral safety switch question - Chevelle Tech
post #1 of 3 (permalink) Old Jul 2nd, 18, 9:11 PM Thread Starter
Just got a new ignition switch and a neutral safety switch in the mail. I am actually reading the instructions from Airtex/Wells. Here is the puzzlement. It tells me to align the switch by putting a .092 pin in the "locating hole". This is aligned front to back. I do that and there is no continuity on the NSS terminals. It also tells me to install said pin in the "service hole" which is on top of the switch. (This produces continuity.)Then install the switch. I assume that I will be using the alignment that produces continuity. So what is the deal with 2 sets of holes? Any thoughts on this ?
JWagner is offline
post #2 of 3 (permalink) Old Jul 2nd, 18, 9:48 PM
Levon
Re: Neutral safety switch question
Can you share the year and a picture ?
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis, Ab. Canada
My Showroom
LevonH is offline
post #3 of 3 (permalink) Old Jul 2nd, 18, 11:01 PM
Jeff is working on a 72 El Camino, column shift.
63 Nova wagon
Philip is offline
