1970 chevelle only starts if I disconnect then reconnect battery - Chevelle Tech
 3Likes
  • 1 Post By George Halpin
  • 1 Post By 71350SS
  • 1 Post By B52bombardier1
post #1 of 8 (permalink) Old Jun 26th, 18, 3:29 PM Thread Starter
Hi
1970 454 ss chevelle, car was fine, then one day, when I went to start it, I just got the click from the starter solenoid a couple of times, the n it would start, but only once
we have checked the battery, battery cables, ignition switch, purple wire, voltage regulator, horn relay and starter(two of them), and yet the car will only start if 1. on a charger, or 2. if the cables are disconnected and reconnected,. and then it will start only once. What is also odd, when I turn the key, the temp gauge freaks out, needle is all over the place unless the car starts. related I do not know.
car will start in both neutral and park so it it's not the neutral safety switch, we've cleaned/checked all the grounds, and there is no alarm on the car. any thoughts what might be going on?
ru4crzn is offline
post #2 of 8 (permalink) Old Jun 26th, 18, 4:04 PM
Re: 1970 chevelle only starts if I disconnect then reconnect battery
Starter solenoid hanging up?
JChilders likes this.
1970 Astro Blue SS396 L34 70SS
George Halpin is offline
post #3 of 8 (permalink) Old Jun 26th, 18, 4:17 PM
What is voltage when key off, key on, cranking, running.
My guess is a loose connection arcing sometimes.
Pioneer4x4 is offline
post #4 of 8 (permalink) Old Jun 26th, 18, 5:00 PM
Lloyd
Sounds like shorted diode in your alternator.
Lloyd
______________________________
"Not all politicians are crooked, but I only trust the
one's that are!'
lloydg1 is offline
post #5 of 8 (permalink) Old Jun 27th, 18, 4:51 AM
Geoff
Some basic testing first to try & isolate the problem.
Using a screwdriver, bridge the large terminals of the solenoid. The starter should crank. If it doesn't crank, then you have a connection problem [ corroded/loose terminals etc ], battery problem, or the stater motor.
If the starter cranks ok, then the problem could be poor connections, the sol itself, ign sw, wiring etc.
Gtogeoff is offline
post #6 of 8 (permalink) Old Jun 27th, 18, 5:21 AM
Check the ground at the block. Take it off clean it really good and put it back on really tight. You can try running a jumper cable from the ground terminal to the battery to the block somewhere and see if that makes a difference and starts. That would isolate the problem
67-468 is offline
post #7 of 8 (permalink) Old Jun 28th, 18, 11:02 PM
I would beg borrow or steal a good battery and see if that fixes it.That's why I like having a couple cars with the same battery.Pop one out of one car and try it in another.
If the battery tests out healthy check for a voltage drain thats weakening the battery by constantly drawing on the battery's available voltage.
Remember this a healthy battery should start an engine multiple times without it going dead.
B52bombardier1 likes this.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #8 of 8 (permalink) Old Jun 29th, 18, 7:30 AM
Get your battery "load tested" at an auto parts store - usually a free test. This analysis will tell you how many amps it can deliver for starting current. While a voltage measurement at the battery is an important number, it is only half of the equation. Volts x amps = watts . . . the ability to do useful work such as spinning a starter motor.
Sent from my SAMSUNG-SM-N900A using Tapatalk
71350SS likes this.
B52bombardier1 is offline
