Wire insulator - Chevelle Tech
  • 1 Post By MarkP
post #1 of 6 (permalink) Old Jun 25th, 18, 5:27 PM Thread Starter
James
Wire insulator
Iím going to be pulling my motor soon, so Iím going to clean up the wiring in the engine bay. What wire insulator would you recommend to keep it packed and clean looking?
Thanks!
69Chvll is offline
post #2 of 6 (permalink) Old Jun 29th, 18, 11:40 PM
Kev
Re: Wire insulator
I have no idea what you're asking.
66sc is offline
post #3 of 6 (permalink) Old Jun 29th, 18, 11:56 PM
Al
Re: Wire insulator
Split wire loom, Easy to work with. The split lets you put the wire through without having to remove the end terminals. Cheap, but won't take extremely high heat. Get various sizes. For areas around headers and to starter I would use some high heat type of loom. I like to wrap the end with cloth electrical tape with the end of the tape on the loom. Makes it look sort of stock. Then I use a small zip tie to keep the tag end from coming loose.
https://smile.amazon.com/s/ref=nb_sb...=1A94FJN9FVVOD
https://www.jegs.com/i/JEGS/555/32012/10002/-1 good to 500 degrees.
https://www.jegs.com/i/Thermo-Tec/893/18050/10002/-1 good to 2000 degrees.
post #4 of 6 (permalink) Old Jun 30th, 18, 12:02 AM
Mark
Re: Wire insulator
I use TechFlex F6 on the same page that Dutch Max Headwork's linked Amazon page. Really makes the wiring look nice.
'69 Chevelle SS ("NOT" ON THE ROAD NOW! )
ZZ502 Short block
Holley Avenger MPFI
612HP/594TQ
MarkP is offline
post #5 of 6 (permalink) Old Jun 30th, 18, 12:05 AM
Al
Re: Wire insulator
That looks like good stuff.
https://smile.amazon.com/TechFlex-0-...ords=wire+loom
post #6 of 6 (permalink) Old Jun 30th, 18, 12:20 AM
Mark
Re: Wire insulator
It's kind of a pain to put on because it really wants to stay in the round shape, but it is really nice when it is installed. I have multiport fuel injection, and that is a big bundle of wires going to the ECU.
I've even seen it installed around hoses. Nice stuff...
ZZ502 Short block
Holley Avenger MPFI
612HP/594TQ
MarkP is offline
