Weird starter situation - Chevelle Tech
 3Likes
  • 1 Post By 71350SS
  • 2 Post By Philip
post #1 of 9 (permalink) Old Jun 23rd, 18, 10:40 PM Thread Starter
My '72 ElCamino has been parked for several months and it now time for an emissions test. So I did the usual fluid level checks and all that and started it up. When cycling the shift lever (350 turbo, column shift) I get a nasty noise going from neutral to drive. It sounds like the starter engaging.
So next I shut off the engine, turn the key to "on" and cycle the shift lever and the engine starts. (Without turning the key to "start"). Another weird thing is that when I turn the key very slowly to "start" the lights come on on the dash but the starter does not crank. Turning the key quickly starts it just fine.
Thinking that the ignition switch is providing power to the safety switch I figured that I mis adjusted the ignition switch when I replaced both early this year. Turning the key the slightest amount toward "off" immediately shuts off the engine.
So,, does this indicate a bad ignition switch that is powering the starter at all times? Or something else?
This problem did not exist back a couple months ago when I stored it in the garage. Everything was fine until today. I am very puzzled.
Any ideas??
JWagner is offline
post #2 of 9 (permalink) Old Jun 23rd, 18, 11:05 PM
Re: Weird starter situaltion
You could have a defective ignition switch, so when you move the shifter, it bumps the switch into "start". Or it could be the backdrive mechanism.
agproelco is offline
post #3 of 9 (permalink) Old Jun 23rd, 18, 11:12 PM
Try re-adjusting the ignition switch that may be the only thing wrong.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #4 of 9 (permalink) Old Jun 23rd, 18, 11:26 PM Thread Starter
Just found another weird feature. By turning the key to "start" very slowly the starter does not turn on, but holding the key there and wiggling the shift lever makes it go. So I have two odd things going on. Potentially both switches are :
1. screwed up
2. misadjusted
3 made in China
But worked fine prior to parking the car for months. The car was stored in a garage and in a nice dry environment.
JWagner is offline
post #5 of 9 (permalink) Old Jun 24th, 18, 2:29 AM
Geoff
Wiggling the shift lever is probably moving a mis-adjusted Neutral/Park switch into the correct position for starting. The contacts should measure continuity in N & P, which completes the circuit to the starter sol so that the starter can crank.
Not sure of your type of ign sw but if it uses a connecting linkage of any type, it might also need adjusting.
So you may have two separate problems.
Gtogeoff is offline
post #6 of 9 (permalink) Old Jun 24th, 18, 11:20 AM
Re: Weird starter situation
Jeff replace the neutral safety switch. I have run into this before, the internal contacts come apart and allow the starter wire to pick up voltage from the back up light hot terminal when the shifter is moved. First time was on a friends Nova, had me scratching my head for awhile as I was diagnosing it over the phone.
DUTCH MAX HEADWORK and SSJohn like this.
63 Nova wagon
Philip is offline
post #7 of 9 (permalink) Old Jun 24th, 18, 12:08 PM Thread Starter
Sounds good. I still am wondering why the ignition switch will activate the starter when turned quickly, but will not do so when fully turned slowly. This deal is irksome because both switches were new at the start of the year when I changed out the steering column. Life is just full of mysteries these days, it seems. Thank you for solving this one!
JWagner is offline
post #8 of 9 (permalink) Old Jun 24th, 18, 12:45 PM Thread Starter
I had a small brainwave on this. I pulled off the connector for the backup lamps and the problem went away. Thanks again.
JWagner is offline
post #9 of 9 (permalink) Old Jun 24th, 18, 12:54 PM
That sounds like a short in the neutral safety switch.
{edit} There I go again, posting without reading replies first.
This Thread is more than 420 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
