Back up switch - Chevelle Tech
post #1 of 7 (permalink) Old Jun 22nd, 18, 6:31 AM Thread Starter
Back up switch
1979 ss396. 4 speed manual floor transmission. Reverse lights stay on constantly. Where is the back up switch located? And what color wires should I be looking for? Can’t find it near the linkage. Car only has a guest shifter but rear is stock. Anyone have any photos? Thank you.
Erics512 is offline
post #2 of 7 (permalink) Old Jun 22nd, 18, 9:19 AM
Re: Back up switch
Do you mean a 70 SS?
RealRed70 is offline
post #3 of 7 (permalink) Old Jun 22nd, 18, 9:29 AM
Re: Back up switch
If your car was converted to a manual, the switch is on the column under the dash.
oldcutlass is offline
post #4 of 7 (permalink) Old Jun 22nd, 18, 10:11 AM
Re: Back up switch
Is the shift collar rotated by the back drive linkage?
wire colors should be pink and green I think
post #5 of 7 (permalink) Old Jun 22nd, 18, 10:15 AM
blm
Re: Back up switch
At the base of steering column is a connector with several wires. You will find a pink and light green in that bundle. Those are the reverse light wires. Don't know how it is set up for an automatic but a manual originally had a back drive that was.used to activate reverse lights. Most manual cars have a plunger switch that mounts to the back side of the shifter body. When the shifter is put in reverse the lever pushes against the plunger switch which has two wires running to the pink and green that are at the base of the steering column.
blm is offline
post #6 of 7 (permalink) Old Jun 22nd, 18, 1:03 PM Thread Starter
Sorry. Yes. 1970 ss. All original. Original 4 speed on the floor. No column shifter.
Erics512 is offline
post #7 of 7 (permalink) Old Jun 22nd, 18, 4:05 PM
blm
Re: Back up switch
Does it have headers? If yes then you will know what happened to the backdrive. They don't work with headers.
Summit Racing sells the part you need it is Hurst part #248003
blm is offline
