1966 Chevelle Knee Knocker Tach - Chevelle Tech
post #1 of 7 (permalink) Old Jun 9th, 18, 12:51 PM Thread Starter
Unhappy 1966 Chevelle Knee Knocker Tach
Who makes a Good Knee Knocker Tach besides GM ?
I just fired up up my 1966 Chevelle and the Knee Knocker Tach I purchased from Ground-Up lasted about 20 minutes in to the Break-in of the engine it was the 0-6000 ? Now sits a 2000 rpm and doesn't move. Is this the proper place to Post or should it be under Engine ? Thanks Clint
Clintsblue66 is offline
post #2 of 7 (permalink) Old Jun 9th, 18, 1:05 PM
rick
Re: 1966 Chevelle Knee Knocker Tach
If you haven't had the tach too long I'd be calling GU and get another 1, I've had hit & miss luck with them on that and shipping back was on me 99% of the time
shovelrick is offline
post #3 of 7 (permalink) Old Jun 10th, 18, 8:01 PM Thread Starter
Hi Thanks for the response unfortunately I purchase stuff when I have extra money ! So I have been sitting on the Tach for a couple of years while restoring my Car. So it's over a year old, even though it only lasted 20 minutes being used . Keith B purchased his Tach at Ausleys and has been using it for 10 years, So I guess I will try them next ?
I wish I could purchase an extended warranty ! LOL what a waste of money
post #4 of 7 (permalink) Old Jun 11th, 18, 8:33 PM
Did you double check the connections? still have power to the tach? Just thinking out loud, I'd make sure it was the tach before ordering another one...
TC #1366
'70 Chevelle 427 Stroker Sold
'66 Convertible Sold
Dual Quad 396 & Conv Int
'66 SS L78
1966_L78 is offline
post #5 of 7 (permalink) Old Jun 16th, 18, 11:07 AM Thread Starter
Yes I checked everything ground and lead wire to coil wire received my new Tach 5600 rpm for the 360hp. I did not remove the housing from the Dash !
They looked to be very similar/identical so I just swapped out internal Tach 1-screw back side wired up and its working so far so good ?
post #6 of 7 (permalink) Old Jun 16th, 18, 11:16 AM
I suggest contacting one of the people on this site that rebuild those tachs, and have a modern day tach movement installed. This way, it will work, and still look period correct. Just a suggestion.
Dave Ray is offline
post #7 of 7 (permalink) Old Jun 27th, 18, 11:15 AM Thread Starter
Exclamation Re: 1966 Chevelle Knee Knocker Tach
Wow Thant's a great idea I didn't know that they can be repaired / restored ? Do you have any info on who I could contact ?
Thanks Clint
