66 volt, regulator capacitor and wires - Chevelle Tech
post #1 of 17 (permalink) Old May 18th, 18, 9:38 AM Thread Starter
john
I got a new voltage regulator and it didn't come with the capacitor and the two wires. Where could i get them from.
ID:	555185   Click image for larger version
ID:	555193   Click image for larger version
ID:	555201   Click image for larger version
johnny5 is offline
post #2 of 17 (permalink) Old May 18th, 18, 11:41 AM
Re: 66 volt, regulator capacitor and wires
I believe the end of the capacitor has a number on it like maybe 0.5 and this number is the capacitance value.
You might then look at the parts you need from this place below and see if it matches up to what you have:
1967 1968 1969 Camaro & Firebird Radio Capacitor Mounts On Voltage Regulator GM# 1964086 - 1967, 1968, 1969 Camaro Parts - NOS, Rare, Reproduction Camaro Parts for your Restoration
1967 1968 1969 Camaro & Firebird Voltage Regulator Ground Wire - 1967, 1968, 1969 Camaro Parts - NOS, Rare, Reproduction Camaro Parts for your Restoration
Always working on something:
Jim Streib is online now
post #3 of 17 (permalink) Old May 18th, 18, 4:49 PM
Weldon
I got a capacitor from Rockauto.com.
It was for my 67 Cougar, but it's the same capacitor.
Weldon
64 El Camino
67 Mercury Cougar
66 Chrysler 300
2011 Harley Davidson TriGlide
Team Chevelle #5157
wihaltom is offline
post #4 of 17 (permalink) Old May 19th, 18, 7:12 AM Thread Starter
john
That one i got at autozone.
johnny5 is offline
post #5 of 17 (permalink) Old May 19th, 18, 8:26 AM
johnny
any reason you did not get the electronic voltage regulator?
454bbss is offline
post #6 of 17 (permalink) Old May 19th, 18, 9:42 PM
Unless this is a concours restoration, you don't need the ground wire attached to the voltage regulator frame. That came into play on cars that originally came with rubber mounts on the voltage regulator that dampened vibrations. Since rubber doesn't conduct, and the mounting frame of the regulator needed a ground connection, the wire was a necessity. Simply attach the voltage regulator directly to the radiator support sheet metal. The capacitor is to suppress "hash" that would be heard on the radio, especially on the AM band.
I will agree with the above...why did you choose to go with a mechanical regulator? The modern units are not built properly compared to the originals and can cause a lot of grief. Most people take a modern solid state regulator like the Wells/Duralast VR-715 available at AutoZone, carefully remove the cover and install the original Delco-Remy cover in its place. If you do this, you must transfer the gasket from the original regulator or smear dielectric grease between the cover and base to prevent moisture from getting inside the regulator.
Coppertop is offline
post #7 of 17 (permalink) Old May 20th, 18, 10:19 AM Thread Starter
john
Here's the numbers off the old capacitor 1964086 DR 5MF, 12V N 1119 , 7A 515. Here's a couple pictures of the new one it looks the same just doesn't have the wires and capacitor on it. They look the same thought just missing the wires.
ID:	555953   Click image for larger version
johnny5 is offline
post #8 of 17 (permalink) Old May 21st, 18, 6:08 AM
Geoff
The numbers probably mean 12v rated [ working voltage ], 0.5 microfarad. A fairly common capacitor. If you want to hide the cap, you could buy a polyester, polycarbonate or Mylar capacitor from an electronics store & wire it in under the cover. Use neutral cure silicon to to hold it in place, make sure it does not obstruct contact operation.
They are not polarity sensitive. Look at the old VR to see where the wires go.
You may not be able to get 0.5, but 0.47 is ok.
Gtogeoff is offline
post #9 of 17 (permalink) Old May 21st, 18, 2:09 PM Thread Starter
john
I went and ordered the 1964086 DR 5MF along with the ground wire from the Camaro site. They look the same i hope they work.
johnny5 is offline
post #10 of 17 (permalink) Old May 21st, 18, 9:39 PM
rkd
Ron
There is or used to be a capacitor near or connected to the voltage regulator?
Iirc there was one tied to the points, never heard of one on the voltage regulator.
My 66 seemed to have a harness and connector that just plugged into a standard autozone replacement regulator, I think. Have to look in the manual later on.
rkd is offline
post #11 of 17 (permalink) Old May 21st, 18, 10:16 PM
Why not just reuse the ground wire? You could have also cleaned up reused the capacitor.
oldcutlass is offline
post #12 of 17 (permalink) Old May 22nd, 18, 1:30 AM Thread Starter
john
Both are in bad shape that's why i don't want to re-use the oll ones.
johnny5 is offline
post #13 of 17 (permalink) Old May 22nd, 18, 2:09 PM
Patrick
I wonder if this voltage regulator is really necessary when switching to a new alternator, like the Delco 10si which is internally regulated. I did that last year, plugged off the connector to the external Voltage Regulator we see here in these pictures and everything is working as before, voltage is stable too, battery charging etc.
Is there a drawback when getting rid of it completely, something I donīt see here?
I donīt want to hijack this thread, if you want me to open a new one I will. It just seems a lot of knowledgeable people came in here with a lot of background information about those external voltage regulators :-)
64 El Camino, 454/TH350/3.36-one-tire-will-die-first-style-rear
FarmerJoe is offline
post #14 of 17 (permalink) Old May 22nd, 18, 2:42 PM
Hey, a good discussion is always helpful.
I "think" the original poster is keeping his old style 1966 externally regulated alternator which requires the external regulator. If he were to change out the old style externally regulated alternator for one that has the internal regulator then the external regulator would either get abandoned or at least unplugged and if needed a jumper plug plugged into the old 4 wire connector to allow a new alternator to get the proper signals for it to work as well as maintaining operation of the original GEN light in the dash.
I will add too, that sometimes you can clean up and reuse things but I have seen a bunch of capacitors replaced through the years due to them drying out internally either due to age and/or being close to excessive heat. When this happens then do not do what they were originally designed to do.
FarmerJoe likes this.
post #15 of 17 (permalink) Old May 22nd, 18, 3:40 PM
Patrick
Originally Posted by Jim Streib View Post
[...]If he were to change out the old style externally regulated alternator for one that has the internal regulator then the external regulator would either get abandoned or at least unplugged and if needed a jumper plug plugged into the old 4 wire connector to allow a new alternator to get the proper signals for it to work as well as maintaining operation of the original GEN light in the dash.
Jim, thank you very much! Now things start to clear up a bit :-) Only 2 days ago I ran across a Alternator conversion kit for Si Alternators and I was not sure what the intended use was. It was this one over here: https://www.ss396.com/el-camino/27555.html. But now it makes sense :-)
And for johnny5, maybe this part I found in the same shop may have been useful if I had found it a day ago :-) https://www.ss396.com/el-camino/GRC-12834.html
This Thread is more than 424 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
