68 dash led bulb upgrade - Chevelle Tech
post #1 of 4 (permalink) Old May 17th, 18, 9:20 PM Thread Starter
johnny
i just replaced dash and turn the power back on and the led work great much brighter on dash,but flasher seems to be malfunctiong,shows green and slowly dims,want flash and no turn signals,should i have replaced with a newer hazard fuse? thanks
454bbss is offline
post #2 of 4 (permalink) Old May 18th, 18, 1:00 AM
Vince
Re: 68 dash led bulb upgrade
did you go led turn or brake lites also??
a newer ''no load'' flasher should help with issue
VinceS427bb is offline
post #3 of 4 (permalink) Old May 18th, 18, 6:22 AM
Geoff
I think Vince nailed it, you need the compatible flasher with LED lights. The original type will not work.
Gtogeoff is offline
post #4 of 4 (permalink) Old May 18th, 18, 4:55 PM
Weldon
If the turn signals were flashing fast, I would suggest the no-load flasher, but he says "flasher seems to be malfunctioning,shows green and slowly dims,want flash and no turn signals". Not sure what is turning green, but it doesn't sound like a flasher issue.
454BBSS, Do you mean the actual turn signals don't work or that the indicators don't work??
Weldon
64 El Camino
67 Mercury Cougar
66 Chrysler 300
2011 Harley Davidson TriGlide
Team Chevelle #5157
wihaltom is offline
This Thread is more than 749 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
