1971 Dash Harness... - Chevelle Tech
  • 1 Post By LeoP
post #1 of 6 (permalink) Old May 14th, 18, 10:20 PM Thread Starter
Somewhere in the future, I am going to have to replace the dash harness in my 71. The fuse block is hanging loose - the only attachment point that may still work is the lower left screw, but it will not stay in the hole (I have tried to use a 'punch' to rework the hole, but it did not work).
So, I have been looking at different harnesses. American Autowire has one, but I believe that all of their harnesses use the newer ATO style fuses. Lectric Limited has an exact reproduction harness for the same price (glass fuses).
Has anyone here installed either of these?? If so, how much time should I allot for changing it out?? I have no problems with residential/commercial wiring, but automotive wiring has never been my thing. Both harnesses should plug directly in to everything else and the bulkhead should also work.
If anyone can give me some guidance on this, your input will be greatly appreciated. Thanks in advance.
My Chevelle w/ open headers:
1971-Chevelle is offline
post #2 of 6 (permalink) Old May 14th, 18, 11:11 PM
Re: 1971 Dash Harness...
You'll need to remove the dashboard from the car. Here are the steps: https://www.chevelles.com/forums/26-i...step-step.html
Where there are screws that screw into the plastic of the dash face, you'll find the plastic threads will pull out very easily. You'll think the screw is getting tight but then it'll keep turning.
Grounds are important. Any dash brackets where ground lugs are to go on need to be cleaned up shiny with a wire brush. I suggest you get some of those star-toothed grounding washers to help get a good ground.
The entire load of the windshield wiper motor and washer get it's ground through the dash wiper switch body. Make sure it's well grounded.
Get all new cluster bulbs, test them before installing. Check the ones in the AC/heater control.
Consider a new headlight switch. The dimmer rheostats can get iffy over the years.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #3 of 6 (permalink) Old May 14th, 18, 11:17 PM
leo
JMHO, I would go with the ATO fuse setup!
paul bell likes this.
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #4 of 6 (permalink) Old May 14th, 18, 11:35 PM
Oh yeah, while you're in there, you'll probably find all the foam seals in the AC/heater ducting has evaporated. You'll spend time trying fixing them up.
If your car has AC, make sure the passenger lap vent that's attached to the dash under the glove box is attached to the bottom of the dash before you re-install the dash. It's a huge pain to install afterwards.
How may I help you?
1999 Trans Am-500hp
post #5 of 6 (permalink) Old May 14th, 18, 11:54 PM Thread Starter
I appreciate the info, but I really need to know how much time to allot for the installation. This is my daily driver and I can't have it down longer than necessary.
post #6 of 6 (permalink) Old May 15th, 18, 12:20 AM
I'd say at least a day. Figure more for surprises.
How may I help you?
1999 Trans Am-500hp
This Thread is more than 753 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
