Windstar dual electric fan wiring... Relay sizes? - Chevelle Tech
  • 1 Post By paul bell
post #1 of 8 (permalink) Old May 14th, 18, 4:00 PM Thread Starter
Ben
I wonder if someone who has gone through this already can help me out.
There are a zillion threads on wiring up electric fans and the windstar fans many with conflicting information or just different information, and I'm having a hard time finding the answers i'm looking for.
What size relays should one use for THIS setup?
I see threads where some people are running 30 or 40 amp relays, other threads people are advocating 70+ amp relays and solenoids, still others suggesting to run dual 30 amp relays in parallel... Not quite sure what to make of all this.
What kind of AMP draw do these specific fans actually need (I'm running them individually) and what does that equate to in real world Relay, fuse & wire sizing?
Thanks-
Ben
RAMBO is online now
post #2 of 8 (permalink) Old May 14th, 18, 9:00 PM
Re: Windstar dual electric fan wiring... Relay sizes?
Donít run relays in parallel.
I believe these fans draw about 30 amps when running. The start-up (in-rush) current will be much higher. Good relays have a good in-rush rating, but I personally wouldnít bother with standard relays. Iíd go heavy duty 75 or 80 amp relay for each fan for reliability.
Coppertop is offline
post #3 of 8 (permalink) Old May 15th, 18, 12:55 AM Thread Starter
Ben
Would something like this work well?
RAMBO is online now
post #4 of 8 (permalink) Old May 15th, 18, 1:19 AM
I found a thread on these Windstar fans on a diesel forum where the guy tested fuses small to large seeing which one didn't blow. Looks like 25 amps held.
Most Bosch style relays are good to 30 amps, the Panasonic versions , 40 amps.
My Toyota fans draw a solid 20 amps each and I've never blown a 25 amp fuse-or a 30 amp Bosch relay.
My setup runs the fans in series at half speed and when things heat up, they change to independent at full speed.
A favorite tool of mine is a KD Tools 2423 current meter. Two slots on the back, just lay the wire in the slot and the amps show. 75 & 600 amp scales. https://www.ebay.com/itm/23276806652...item36320ed3dc
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #5 of 8 (permalink) Old May 15th, 18, 8:29 AM
Best thing to do is find the wiring diagram for the vehicle the fans came out of, you'll have factory engineering advice on what to run.
I did a quick google, all I could find was this: https://soltani.co/upload/2000-ford-...mp-diagram.jpg
Looks like 50 amps fuse to run both fans for an 01 Windstar.
I'm running 2002 Camaro fans on my chevelle, they fit really nice and work well. Have them wired up like factory (also like how Paul's is wired).
*Jeff*
LQ4 / T56 Swap Project Thread
Hotwire is offline
post #6 of 8 (permalink) Old May 15th, 18, 9:07 AM
Nice wiring diagram Jeff.
And those 4th gen F-body are very versatile.
I like the GM way of wiring them. The load is split between two smaller fuses, wires and relays and there's no dropping resistor. The Ford way uses a 50 amp fuse and I'm sure a pretty thick feed wire. I actually drew out and used the series/parallel relay setup in the 80's, before GM used it.
With the GM method, unless things really heat up, the fans stay in low speed (running in series with fans at half speed) with minimal current load.
Folks, don't forget an at least 100 amp alternator when using electric fans.
Hotwire likes this.
How may I help you?
1999 Trans Am-500hp
post #7 of 8 (permalink) Old May 15th, 18, 10:16 AM
Yessir, in series you can hardly hear them and they're pushing a decent amount of air through.
*Jeff*
Hotwire is offline
post #8 of 8 (permalink) Old May 16th, 18, 6:04 AM
Geoff
Find out how much current the fans draw. You use a relay that is too small [ contacts too small for the current ], but you cannot use a relay that is too big.
In my opinion, you should use a relay that can switch 50% more current than the fan[s] draws.
Gtogeoff is offline
This Thread is more than 396 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
