Sorting out a harness - Chevelle Tech
post #1 of 1 (permalink) Old May 13th, 18, 11:54 PM Thread Starter
Tony G
64 SS wire harness. The previous owner ran 2 separate wires from the fuse block. One for the HEI and the other for the starter. In working with the original harness off the engine side firewall, I found the white resistance wire he eliminated but there is a purple wire also cut. Anybody know if I can use this purple one for the starter instead of having a separate one back to the fuse block. The which the schematic shows purple wire heading back to the ign switch.
'64 SS Coupe, 4 spd Muncie M-20, 12 bolt 3:42, 350sb 9.75:1, Edelbrock RPM top kit with roller cam, EB 600cfm carb.
Weekend driver....
Weekends need to be 4 days long every week.....
Antalamo is offline
Tags
purple starter wire
This Thread is more than 498 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
