68 dash harness has a few cut wires - Chevelle Tech
post #1 of 4 (permalink) Old May 13th, 18, 7:28 PM Thread Starter
johnny
what is recommended to join these two wire back together? will butt connectors work with heat wrap. THANKS
454bbss is offline
post #2 of 4 (permalink) Old May 13th, 18, 7:35 PM
Al
Re: 68 dash harness has a few cut wires
Sounds like a solid plan to me.
DUTCH MAX HEADWORK is offline
post #3 of 4 (permalink) Old May 13th, 18, 7:44 PM
What two black wires?
Coppertop is offline
post #4 of 4 (permalink) Old May 13th, 18, 7:47 PM
rick
I would slide the needed size heat shrink over 1 wire and twist the wires together end to end not side by side then solder and slip the heat shrink over it and heat it, you'll never have a problem with it but I've done a million crimp connections on a/c stuff without problems too
shovelrick is offline
This Thread is more than 755 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
