Where to tie in HEI? - Chevelle Tech
 9Likes
post #1 of 35 (permalink) Old May 13th, 18, 5:59 PM Thread Starter
I just started my engine on my 66 today for the first time after rebuild, it went well except that I switched over to an HEI distributor and I'm having an issue. I eliminated the resistor wire to the old points distributor and replaced it with a heavy guage wire which I ran from a spade lug n the fuse panel labelled "IGN Fused" directly over to the distributor. When I tried to start the car, it ran off of the pink wire from the starter while cranking but died with the key in the run position. I moved the wire up one spot on the fuse panel to "BAT Fused" and the car ran for my cam break-in. When I went to shut it off, it kept running and I had to pull the wire from the fuse panel to shut it off. That makes sense to me but why didn't IGN Fused work? Was "IGN Fused" incorrect or do I have to go looking for an issue with it?
Dansk is offline
post #2 of 35 (permalink) Old May 13th, 18, 6:37 PM
Re: Where to tie in HEI?
The IGN terminal in the fuse box is powered by an adjacent fuse, test the terminal with the key on to see if it has power. If not check the fuses next to it for a blown one.
oldcutlass is offline
post #3 of 35 (permalink) Old May 13th, 18, 7:38 PM
Earlier vehicles don't have a mutually bussed ignition switch where as you may encounter the ignition switched circuits dropping out during cranking.
A 12 volt test light is your friend here.....
As Eric stated, check the IGN slot connector for power with the key "on".
Now see what happens with the test lamp on the same IGN slot connector as you crank the starter. Does it still stay on?
Coppertop is offline
post #4 of 35 (permalink) Old May 13th, 18, 8:16 PM
Just turn on the ignition and check for +12 on the coil using a DVM, if itís not there, sounds like thatís is the case, check fuses.
1970 Cranberry Red SS396 TH400 AC 3:31 Posi -as it was born
MySS396 is offline
post #5 of 35 (permalink) Old May 14th, 18, 6:01 AM
Geoff
Congrats on using HEI, a great ign. HEI needs the full 12v. The easiest way to ensure it gets it & keep your original wiring intact is to use a relay to power the HEI. Whatever wire[s] were connected to the old coil +ve terminal, use these to power the relay. Connect the supply to either the alt main terminal or bat +ve terminal for max voltage to the HEI. Use an inline 10 amp fuse in this line.
JWagner likes this.
Gtogeoff is offline
post #6 of 35 (permalink) Old May 14th, 18, 6:46 AM Thread Starter
Thank you, I think that what is happening is that the same IGN terminal on the fuse box is also feeding my 2004r lockup and I'm getting a voltage drop so Geoff is right on with how to fix that.
Dansk is offline
post #7 of 35 (permalink) Old May 14th, 18, 6:11 PM
A relay is no good way to fix a system that really doesn't need one. They are problem prone, add extra stuff to go wrong, and just aren't needed to do it right.
Dave Ray is online now
post #8 of 35 (permalink) Old May 14th, 18, 8:34 PM Thread Starter
Worked like a charm. I'll agree with Dave that I'd rather not use it in an ideal world but I think that would lead to a while new wiring harness, maybe next winter. For now, it's running.
Dansk is offline
post #9 of 35 (permalink) Old May 15th, 18, 5:37 AM
Geoff
If relays were no good, the sides of the roads would be littered with broken down cars...Sourcing a power supply for ign through 30 or 40 year old wiring harnesses & plugs/sockets probably has more risk of failure than installing a new relay & fresh wiring.
Using a relay ensures you get max voltage for HEI, which is voltage sensitive.
Picking up 12v from the fuse panel requires just as much messing around as fitting a relay & will not supply as high a voltage as a relay connected the way I said in the earlier post. I often fit the relay to the base of the dist, at the rear. Neat tidy, out of sight. Short run of wire along the intake to the alt main terminal.
I know of at least two companies, DUI & Ice Ign, that offer voltage boosters that increase voltage for inductive [ HEI ] ign systems. They obviously think maximising voltage is very important......
wihaltom likes this.
Gtogeoff is offline
post #10 of 35 (permalink) Old May 15th, 18, 6:30 AM
A 12 gauge wire between the IGN and the coil should have brought a little over 12v and fired right up
MySS396 is offline
post #11 of 35 (permalink) Old May 15th, 18, 1:32 PM
Relays are NOT reliable, none of them, haven't ever been, aren't now, never will be reliable, and, what sensible person needs an extra unreliable electrical device to monitor, and its added wiring, I never have. But, then, I choose to do it the RIGHT way in the first place. Comes from doing ignition systems for a living, and fixing Rube Goldberg stuff, like failed relays, EVERY DAY.
paul bell likes this.
post #12 of 35 (permalink) Old May 15th, 18, 1:59 PM Thread Starter
You've helped me out numerous times Dave so I hate to contradict you but I have to ask, if the relay is such a bad idea what would you suggest? Rip out my original harness and fuse block to start fresh? Great idea but I save stuff like that for the off-season. The car is 50+ years old and never designed for HEI. The IGN circuit won't do it but the relay idea is working. If the relay fails, it's 4 spade connectors and put another one on.
Dansk is offline
post #13 of 35 (permalink) Old May 15th, 18, 2:26 PM
True, a relay fixes the symptom for people that don't know how to properly diagnose the problem but it is another extra added on unnecessary future thing to fail.
MySS396 likes this.
post #14 of 35 (permalink) Old May 15th, 18, 2:58 PM
I'm not sure if anyone ever hear of "Vital Relays" but when I worked on wiring transportation control cabinets, they were used. 20+ years ago they were $1200 each if I recall. They are super high quality, sealed with visible contacts. They have no springs, and are gravity powered, unless gravity ceases to exist, or the cabinet falls over, they fail in the "Safest" state.
BUT (remember, everything before "BUT" is B.S.)
https://washington-dc-metro.com/2011...of-10-million/
I fully understand benefits of relays, both in isolation, and in limiting current on controls.
How many millions of cars/trucks on the road power HEI through the ignition switch for decades with no issues?
In many cases fault tolerance, just adds additional single points of failure.
Pioneer4x4 is offline
post #15 of 35 (permalink) Old May 15th, 18, 7:38 PM
We all have our opine's. However in most cases the relay is extremely reliable and will provide full battery voltage to the HEI without going through yards of 50 y/o wire.
This Thread is more than 428 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
