67 no power to compressor - Chevelle Tech
 3Likes
  • 1 Post By pyasher
  • 2 Post By bobm67
post #1 of 13 (permalink) Old May 13th, 18, 11:15 AM Thread Starter
bob
I have no power to green wire on compressor. The black ground wire has ground. I cleaned the contacts and checked the inline fuse with orange wire leading out of it. I am not good at a/c wiring, I looked at the wiring diagram and I am lost. Thanks for any help
bobm67 is offline
post #2 of 13 (permalink) Old May 13th, 18, 4:49 PM
Re: 67 no power to compressor
any help here? anybody know where the power to the green wire comes from?
Bob, has this ever worked? Any recent changes on the car?
post #3 of 13 (permalink) Old May 13th, 18, 5:25 PM
Al
Need an A/C wiring diagram for a 67 chevelle in order to help. Pop one off and post it...Then we can trace it.
DUTCH MAX HEADWORK is offline
post #4 of 13 (permalink) Old May 13th, 18, 6:12 PM
Perry
I am having the same problem with my 72 - just installed a idle up solenoid on the Q Jet - car originally had a idle stop solenoid - I took power off the green signal wire going to the A/C clutch. I will check my wiring diagram and fuses etc. - will let you know what I find...
pyasher is offline
post #5 of 13 (permalink) Old May 13th, 18, 6:25 PM
Al
Your vehicle has a completely different electrical lay out. To keep from getting the two cars and wiring confused, please start another thread and we'll see if we can help out.
post #6 of 13 (permalink) Old May 13th, 18, 7:43 PM
These cars have a dedicated compressor switch. It's sort of a spring loaded snap-action reed switch on the later years, where the early years can have a bracket mounted plunger switch.
The contacts can wear out from the internal arcing over time.
Coppertop is offline
post #7 of 13 (permalink) Old May 14th, 18, 6:50 AM Thread Starter
bob
Were is the switch located, and is there a easy way to test it. The A/C was rebuilt in 2001 and still has R-12. It's worked every year all I have to do is clean the connects at the compressor but not this year. If it was low on R-12 would it have power to the green wire on the compressor.
bobm67 is offline
post #8 of 13 (permalink) Old May 14th, 18, 11:06 AM
Andy
I did ac on a 67 GTO last year and it was a switch on top of the inside heater case actuated by the mode door cable.
Andy's Auto Repair is offline
post #9 of 13 (permalink) Old May 14th, 18, 2:50 PM Thread Starter
bob
Was it adjustment on the A/C cable or bad switch. It feels like the cable moves something when you move all the way to the left. Thank you
bobm67 is offline
post #10 of 13 (permalink) Old May 14th, 18, 3:30 PM
Andy
It wound up being a bad switch. I used an activation switch from a nitrous kit and it bolted right in.
post #11 of 13 (permalink) Old May 16th, 18, 6:26 AM
Perry
Thanks Dutch - it was the thermal switch on the drivers side by the compressor - jumped it out and 12 V are back. According to all I talked to it is a common problem and most folks just jump it. I have ordered a reproduction one off e bay.
pyasher is offline
post #12 of 13 (permalink) Old May 17th, 18, 10:10 AM Thread Starter
bob
Thanks Andy for you help. It was dirty terminals on the switch on top of heater box behind glove box.
LeoP and Andy's Auto Repair like this.
bobm67 is offline
post #13 of 13 (permalink) Old May 20th, 18, 10:59 PM
Kev
Wiring is wiring until it gets hacked over the lifespan of the vehicle.
Pretty sure the insulation on the wire running the (pick something) has a color, it's in a harness, and the harness has only a few ends. Find the same color wire exiting the harness, and follow. Repeat.
66sc is online now
This Thread is more than 778 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
