Blinker switch problems? - Chevelle Tech
 2Likes
  • 2 Post By Toppless72
post #1 of 5 (permalink) Old May 10th, 18, 5:11 PM Thread Starter
Just got a new blinker switch installed and had problems, Both back blinkers would turn on as if the hazards were on no matter which way you turned them, Yet the front blinkers worked fine, However if you had the blinkers on and pushed the brake light whatever front blinker was working would go to a solid instead of flashing. And when you push the brakes at any time both green blinker indicators on the dash light up? Just got a new switch hoping that’ll fix it, Anyone got any suggestions if problem isn’t gone?
gauging is offline
post #2 of 5 (permalink) Old May 10th, 18, 6:06 PM
Re: Blinker switch problems?
Incorrect bulbs? Or one installed the wrong way, busted post?
Pioneer4x4 is offline
post #3 of 5 (permalink) Old May 11th, 18, 10:52 PM
Weldon
I think it's either a bad switch or the wiring got hosed when the new switch was installed.
Weldon
64 El Camino
67 Mercury Cougar
66 Chrysler 300
2011 Harley Davidson TriGlide
Team Chevelle #5157
wihaltom is offline
post #4 of 5 (permalink) Old May 12th, 18, 12:19 AM
You need to start at the beginning to get the best help with your problem.
1. What are you working on? year make and model
2. Why was the turn signal switch replaced? What problems did you have?
3. What, if any, other work was done at the same time?
4. What have you done to troubleshoot the issue?
5. What other new parts were installed recently? Since this work was necessary?
A complete review of your situation will yield quicker and more complete answers to your questions and less guess work.
Toppless72 is online now
post #5 of 5 (permalink) Old May 12th, 18, 4:16 PM
Glen
Low blinker fluid? lol
1968 Chevelle
468 Big Block
Muncie M20 4 Speed
12 Bolt Posi 3.31:1 Gears
glend123 is offline
This Thread is more than 430 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
