1966 Chevelle 4 speed wiring ID - Chevelle Tech
  • 1 Post By David Bates
post #1 of 8 (permalink) Old May 8th, 18, 12:41 PM Thread Starter
Hello guys need some help with wires. Putting a new harness in and I have dark green and a lighter green and a purple and a purple with white strip see photos
Thanks in advance
Thanks KW
KDW66 is offline
post #2 of 8 (permalink) Old May 8th, 18, 1:00 PM
Re: 1966 Chevelle 4 speed wiring ID
IIRC, light and dark purple are for the neutral safety switch... But on a 4-speed, there is no NSS... Are you sure you have the correct harness? I don't recall seeing the Purple wires on my 4-speed harness (factory)...
You can always make a short jumper wire, and connect the dark purple to the light purple to complete the circuit (or even install a switch as an anti-theft device)...
Here are the wires, connected to a column-shift combo switch...
The green wires, Backup switch. These should be connected to a short harness with a large round grommet (3/4" to 1" diameter) that passes through the firewall for a 4-speed car ( floor shift 3-speed too, IIRC)...
Here's the harness...
Here's the approx location of the hole in the firewall. You can see the large grommet with the two terminals...
TC #1366
Sold
Sold
1966_L78 is offline
post #3 of 8 (permalink) Old May 8th, 18, 1:43 PM
Al
Did they use a Clutch Safety switch in 66? My 70 has a switch near the clutch pedal that I think has purple wires running to it.
post #4 of 8 (permalink) Old May 8th, 18, 6:30 PM
No clutch safety switch in 1966. The purple and purple w/white stripe get a jumper in that connector for 4-speed applications.
USAF Retired (1968-1988)
David Bates is offline
post #5 of 8 (permalink) Old May 8th, 18, 10:00 PM Thread Starter
ythe harness is from H&M wiring, confired with them today, said its the right harness. they did tell me to use a 12g jump wire for the purple.....and the green for revers light...thanks
you guys rocks !!
Thanks KW
KDW66 is offline
post #6 of 8 (permalink) Old May 9th, 18, 2:55 AM
you guys rocks !!
A "jumper" wire will work, but it is NOT correct...
The 4-speed harness does NOT have that connector, and does NOT require a jumper wire. (I have had several)
The harness for a 4-speed car has the two purple wires with individual, single-terminal connectors (one male and one female) that plug together...
basically the same functionality, but for $429+++ for a brand new dash harness, I'd expect it to be "correct". Or at least supply a 12 ga Purple jumper wire with the new harness... The connector on your harness is for a column-shift car...
Don't use a jumper for the reverse lights, or they'll be "on" all the time (when ignition on)...
If your aren't going for concours-correct, with a factory shifter, American Autowire makes a "lower" harness for the reverse lights (at the transmission) that is made to use a Hurst switch... The firewall plug (which is easily seen) is the same as the factory connector...
TC #1366
Sold
Sold
1966_L78 is offline
post #7 of 8 (permalink) Old May 9th, 18, 8:58 AM
Contrary to what I posted above, this is correct!
post #8 of 8 (permalink) Old May 10th, 18, 11:15 PM Thread Starter
Thanks for the input ill give them a call and ask for the correct harness.
Thanks KW
KDW66 is offline
This Thread is more than 523 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
