MSD box - Chevelle Tech
 4Likes
  • 1 Post By lucifershammer
  • 1 Post By Brian Narlow
post #1 of 8 (permalink) Old May 5th, 18, 3:34 AM Thread Starter
MSD box
I installed a msd box and now I have run on... has anyone put in the diode they tell you to put in? And which wire to the alternator did you put it on? It says the smaller of the two wires but both of mine are the same... thanks...
Brian Narlow is offline
post #2 of 8 (permalink) Old May 5th, 18, 7:36 AM Thread Starter
I meant msd , damn spell check....
post #3 of 8 (permalink) Old May 5th, 18, 8:11 AM
Al
re: MSD box
You can attach inline of the wire at the voltage regulator that runs from terminal 4 on the voltage regulator to the charging light. Find the regulator, find the plug with blue, white, red and brown wires. Terminal 4 has a brown wire. the diode needs be go inline with the brown wire with the stripe located towards the regulator.
Diodes are used to allow voltage to flow only one way. Make sure the Diode is installed facing the proper direction.
ID:	551081   Click image for larger version
DUTCH MAX HEADWORK is offline
post #4 of 8 (permalink) Old May 5th, 18, 9:54 AM Thread Starter
I am internally regulated ,so I have to add it by the alternator....
post #5 of 8 (permalink) Old May 5th, 18, 9:59 AM
re: MSD box
That makes it easy. Get one of these. Plug it in and go.
https://www.ebay.com/itm/Alternator-...tZw6Dz&vxp=mtr
1972 Chevelle, 454, 2004r, 3.08
lucifershammer is offline
post #6 of 8 (permalink) Old May 5th, 18, 10:38 AM
re: MSD box
I thought I was going to hear about some new-fangled invention, the “mad” box. Couldn’t wait to discover what it was.
People don’t like to have to think in high resolution. Jordan Peterson. That’s why we are forced in to so many binary choices.
Alan F is offline
post #7 of 8 (permalink) Old May 6th, 18, 2:33 PM Thread Starter
Thanks for the advise!!! Ordered the part off e bay!! I thought the couple of comments were funny!!!
lucifershammer likes this.
post #8 of 8 (permalink) Old May 7th, 18, 2:37 PM
Levon
Re: MSD box
corrected the spelling.
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis, Ab. Canada
LevonH is online now
This Thread is more than 435 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
