repro tach stuck - Chevelle Tech
post #1 of 9 (permalink) Old Apr 29th, 18, 1:24 PM Thread Starter
repro tach stuck
Hello,I just installed a complete ss dash conversion in a 72 chevelle.New dash carrier,gauges,harness, ect.....Every thing works except the tach,it seems to be stuck at now 1500 rpm.Started the car after oil change and it was at 0,started car went up to 1200 and stayed.I give it gas and the needle twitches up and not down.Car has and Hei with a tach filter all new.Is the tach junk or is there something I can do with it? I don't want to take the dash apart again, but I will if I have to.
CH72Chevelle is offline
post #2 of 9 (permalink) Old Apr 30th, 18, 6:00 AM
Geoff
Re: repro tach stuck
It could be mechanical - pointer pivot....or electrical. Hard to say. Maybe try & hook up a temporary points ign to see if the tach works.
Gtogeoff is offline
post #3 of 9 (permalink) Old Apr 30th, 18, 8:58 PM Thread Starter
Hello again,I fixed it. New tach was junk,so I replaced it with another new repro tach,different brand repro now it works.
post #4 of 9 (permalink) Old Apr 30th, 18, 9:42 PM
Does the good one have two or three screws in the face of it?
RealRed70 is offline
post #5 of 9 (permalink) Old Apr 30th, 18, 11:34 PM Thread Starter
The tach I just put in and works has two rivets on the face and a needle stop at zero.The tach that came with the gauge cluster did not.
post #6 of 9 (permalink) Old May 1st, 18, 12:11 PM
What manufacturer Tach worked? I just rebuilt my '72 SS dash and used an OER reproduction tach (don't want the same issues after install?)
Team Chevelle Member (20 years and counting...
72soft-top is online now
post #7 of 9 (permalink) Old May 1st, 18, 12:48 PM Thread Starter
Hi,yours looks like the one I had that never worked.I took it out and back to where I bought all of my parts(NEC) and he gave me another new tach and warrantied the broken one,just a plain white chineesium box .
post #8 of 9 (permalink) Old May 10th, 18, 10:37 PM Thread Starter
Hi,again.Second tach bit the dust,stopped working after 1 1/2 days. I'm done with repro junk and not taking the dash apart again.Putting a real tach on the steering column.
post #9 of 9 (permalink) Old May 12th, 18, 7:25 PM
With 2 Tachs failing... it seems it might have something to do with the HEI or filter?
This Thread is more than 745 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
