Converting the Pre-1968 parking lights operation {PHOTOS} - Chevelle Tech
 14Likes
  • 7 Post By Coppertop
  • 4 Post By Tom Mobley
  • 1 Post By Dean
  • 1 Post By David Bates
  • 1 Post By Rich-L79
post #1 of 8 (permalink) Old Mar 11th, 18, 8:49 PM Thread Starter
I was private messaged with a request to explain/re-post this after the photobucket mess left the sticky at the top of the forum ("Helpful headlight switch info") useless with missing pictures. So, for the interim, here's a quick how-to.
Pre-1968 vehicles have an independent wire or wires that feeds the front parking lamp filaments. They are turned on when the headlight switch is pulled out to the first position. When you pull out the switch to the second position (to turn on the headlights), the parking lights turn off.
To change this so your vehicle acts like 1968-current vehicles (where the front parking lights stay on with the headlights, you must remove and relocate the purple wire at the headlamp switch.
Start by removing the (-) battery cable.
Gain access to the headlamp switch.
You'll see the purple wire feed is the furthest to the left in the picture.
http://www.prepostmodern.com/wp-cont...tch_before.jpg
Unplug the connector assembly from the headlamp switch.
Use a very small screwdriver or Packard terminal extraction tool and insert it into the side opposite of where the wire comes out. Notice you are inserting into the smaller cut-out area just below the main cavity that holds the terminal. You press in to bend back the "finger" catch. You then pull on the wire gently to remove.
http://www.prepostmodern.com/wp-cont.../to_remove.jpg
After the wire has pulled out. bend the "finger" back down as shown so it will "catch" again in the new connector cavity.
**Please note, I used the white ground wire as an example. Again, you are moving the PURPLE wire!***
http://www.prepostmodern.com/wp-cont.../to_insert.jpg
Now insert the purple wire in the new cavity location as shown. If the catch is working, you will hear a slight "click" and the connector will be locked into place.
http://www.prepostmodern.com/wp-cont...itch_after.jpg
The purple wire is now relocated from the far left to the bottom right as shown in this particular picture.
By moving the wire, you are effectively linking the front parking lamp filaments to the tail lamp feed...so....when you turn on the headlights now, your parking lamps will stay lit!
Plug the connector back into the switch. Reassemble as needed and reconnect the battery. Test your modification.
Jeff65SS, 71350SS, 427L88 and 4 others like this.
Last edited by Rich-L79; Jan 4th, 19 at 12:49 PM. Reason: Edited imbedded photos (nonsecure site) so they'd at least be clickable links
Coppertop is offline
post #2 of 8 (permalink) Old Apr 1st, 18, 4:23 PM
Re: Converting the Pre-1968 parking lights operation {PHOTOS}
Thanks Joe. just what we needed.
Photosuckit sux. may all of their corporate leadership roast in hell forever.
post #3 of 8 (permalink) Old Apr 1st, 18, 8:05 PM
Good info! I would have assumed that you need to replace the switch with a newer year. Thanks for the great pics.
69SS454 is offline
post #4 of 8 (permalink) Old Jan 4th, 19, 10:01 AM
Yes please pics! I have to do some dash redoing and this mod was on the list while I was in there. To Bill's question, new switch warranted? THNX.
post #5 of 8 (permalink) Old Jan 4th, 19, 12:04 PM
Photos disappeared.
David
davewho1 is offline
post #6 of 8 (permalink) Old Jan 4th, 19, 12:18 PM
Some here https://www.chevelles.com/forums/27-...itch-info.html
davewho1 likes this.
post #7 of 8 (permalink) Old Jan 4th, 19, 12:26 PM
FYI. This is a 1965 Malibu SS harness and headlamp switch.
ID:	582378   Click image for larger version
ID:	582380   Click image for larger version
USAF Retired (1968-1988)
David Bates is offline
post #8 of 8 (permalink) Old Jan 4th, 19, 12:48 PM
Rich
Originally Posted by davewho1 View Post
Photos disappeared.
When this site went to being a secure site (https instead of http) any photo link that is NOT on a secure site will no longer appear. You can post it as a link, but not an imbedded photo. The best option is to load the photos as attachments.
I'll edit Joe's original post to at least provide links to his photos.
Tarheel Chevelle likes this.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
This Thread is more than 520 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
