66 Dash assembly and hardware - Chevelle Tech
 3Likes
post #1 of 9 (permalink) Old Nov 7th, 16, 1:51 PM Thread Starter
I have taken a time out under the hood of our restoration and decided to focus on the interior.
There is nothing in the assembly manual regarding how the dash does together. Some of it is pretty self explanatory but considering I am trying to put a bunch of parts into a bare shell that I didn't originally take apart, its a bit daunting.
One issue I am running into is the 9 screws (7 across the top 1 on each side) where the lower dash meets the upper dash. There are plastic inserts inside, and I am missing 2. I can't find a hardware kit ANYWHERE that seems to meet what I need. My wife called Ground Up and they sounded clueless as to what she was referring to.
Can anyone point me in the right direction?
66ssdan330 is offline
post #2 of 9 (permalink) Old Nov 7th, 16, 2:29 PM
Re: 66 Dash assembly and hardware
AMK Products...
NPD carries AMK, or you can buy direct...
https://www.npdlink.com/store/produc...-111228-8.html
Or direct from AMK
https://www.amkproducts.com/default.htm
G-5608, $8...
You can probably even buy just the 2 you need, but no sure how you'd know which parts to get... $8 is pretty cheap anyway, and you get all 9 with screws, brand new...
TC #1366
Sold
Sold
1966_L78 is offline
post #3 of 9 (permalink) Old Nov 8th, 16, 10:45 AM
AMK has a $30 minimum-order. We have no minimum order, but we do have a $9 minimum shipping. Our prices for AMK kits are identical to buying direct from AMK, and we keep it all in stock (sometimes AMK has to build-to-order, and it can take them a bit longer).
Just some FYI's!!
Don B likes this.
post #4 of 9 (permalink) Old Nov 8th, 16, 1:46 PM
Hank
I have bought AMK Products directly from them and thru NPD also. It's all quality stuff. In the late 60's early 70's I actually worked for a company that made a lot of clips and bolts that were used in our cars. The companies name was Anchor Fasteners out of Waterbury CT. You can tell if it was manufactured by them by looking on the clip or on the head of a bolt and seeing a little Anchor on it.
davewho1 likes this.
HKalin is online now
post #5 of 9 (permalink) Old Nov 8th, 16, 4:31 PM Thread Starter
Thank you to all, we ordered 2 of that kit so we had spare stuff just incase.
Onto whatever the next issue we find is...
post #6 of 9 (permalink) Old Nov 10th, 16, 6:55 PM
Rod
this may help as well
1966 Malibu, 540 BBC FAST XFI EFI, 4L80E Trans, 2800 Stall, Quick Performance 59" 9" Ford Rear End w/3.50 gear
66 Bu is offline
post #7 of 9 (permalink) Old Sep 8th, 19, 10:42 PM
Just some FYI's!!
The link no longer works, are you still selling this?
Need a bunch of interior screws and such for my '66.
Thanks!
GregSnook is offline
post #8 of 9 (permalink) Old Sep 8th, 19, 10:51 PM
Beth
Thanks!
I think you need to contact NPD - National Parts Depot
nashville beth is offline
post #9 of 9 (permalink) Old Sep 9th, 19, 7:01 AM
Thanks, Didn't see the link was from '16, gah. Looked like someone from NPD was in the thread, and thought it might be useful for others to have.
