Window Weatherstrip replacement - Chevelle Tech
  • 1 Post By augy
post #1 of 8 (permalink) Old Mar 3rd, 16, 6:19 PM Thread Starter
Margaret
Wanted to ask before I ruined anything (and I will), how is the old rubber removed from the rear window of a 69 Malibu coupe? The inside was replaced when the new interior panel went in but the outside wasn't done. How much do I need to remove to get to the exterior rubber piece? Sorry about the sideways attachment but you get the idea.
1955 Chevrolet 210
1968 VW Beetle
1969 Chevelle Malibu
VeeDub is offline
post #2 of 8 (permalink) Old Mar 3rd, 16, 7:30 PM
Ron
Re: Window Weatherstrip replacement
There are small Phillips head screws buried in the rubber, you can see them with the window rolled down. Sometimes you may have to lower the window an extra amount by adjust the stops inside the 1/4 panel.
70 Chevelle SS396 (496) Straub roller, 700r4
69 Malibu convertible (sold)
TC #54 Gold
ToocoolZ28 is offline
post #3 of 8 (permalink) Old Mar 3rd, 16, 8:26 PM Thread Starter
Margaret
I saw the screws but the window wouldn't go down far enough to get them all. What kind of screwdriver would fit in there or do I have to remove the panel on the inside? My right angle one didn't fit. I was hoping there was some easy trick to it, but I think not.
1955 Chevrolet 210
1968 VW Beetle
VeeDub is offline
post #4 of 8 (permalink) Old Mar 3rd, 16, 8:35 PM
Need to remove the inner panel to access the window stops. Loosen them, and roll the window down far enough to access the screws. I've only done the fronts on my 70, but can't see those being any different.
70CHEVELLE396 is offline
post #5 of 8 (permalink) Old Mar 3rd, 16, 8:38 PM Thread Starter
Margaret
Ok, that's what I thought. Just didn't want to it. Thanks!
1955 Chevrolet 210
1968 VW Beetle
VeeDub is offline
post #6 of 8 (permalink) Old Mar 4th, 16, 7:56 AM
What I've done to get at those hard-to-get-at Phillips screws, is to use a tiny right-angle ratchet without a drive "shaft". They have an octagonal hole instead of the shaft. Then cut down a #1 Phillips drive bit as short as possible so that only about 1/4" is sticking out of the hole in the ratchet. You should be able to reach inside between the inner and outer quarter panels to get at those screws.
Then have a good supply of #4 x 1/4" Phillips oval-head screws on hand to install the new window fuzzies. After the new fuzzies are on, I paint the screw heads black with a tiny brush so they don't show.
I bought that tiny little ratchet at Harbor Freight for about $5 and only use it for that purpose. Works great.....
65chevelle300post likes this.
When I works, I works hard.
When I sits, I sits loose.
augy is offline
post #7 of 8 (permalink) Old Mar 4th, 16, 10:20 AM Thread Starter
Margaret
I have one of those right angle ratcheting things. Never thought to cut the bit down shorter. Might try that before I disassemble everything. Great idea! Thanks!
1955 Chevrolet 210
1968 VW Beetle
VeeDub is offline
post #8 of 8 (permalink) Old Mar 5th, 16, 9:19 AM
Let us know how it works out for ya......
augy is offline
This Thread is more than 1497 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
