How do I remove Grant Steering Wheel Hub Adapter - Chevelle Tech
  • 1 Post By 757driver
post #1 of 7 (permalink) Old Jul 6th, 15, 5:54 PM Thread Starter
Hey again everyone,
I installed a Grant wheel a while ago, and while tightening the shaft nut, I went a little too far which has caused the plate that sits under the wheel to lightly contact the steering column when I turn. It makes an annoying sound, and I figured I'd finally deal with it.
I pulled the 3 bolts off that hold the wheel to the hub, and I loosened the shaft nut. The hub adapter is still sitting pretty far down on the shaft (it didn't uncompress when I took the nut off). Is this because the hub adapter is holding it down in the position that I tightened it to? Do I need to use a steering wheel puller to take it back off?
Thanks!
1970 Malibu 4-door 307
1973 Camaro RS
evilws6 is offline
post #2 of 7 (permalink) Old Jul 6th, 15, 6:24 PM
Jerry
Re: How do I remove Grant Steering Wheel Hub Adapter
Use a puller. The big center nut forces onto the splines in a tight friction fit.
hydro462 likes this.
757driver is offline
post #3 of 7 (permalink) Old Jul 6th, 15, 6:32 PM Thread Starter
Well I was able to remove the hub adapter, but the components that sit behind it are still compressed inwards. Do I need to get the steering column tool and remove that center retainer and re assemble?
1973 Camaro RS
evilws6 is offline
post #4 of 7 (permalink) Old Jul 6th, 15, 7:01 PM
How about some pictures? You will get many more responses with pictures.
RealRed70 is offline
post #5 of 7 (permalink) Old Jul 6th, 15, 9:53 PM Thread Starter
I resolved the problem. I took everything apart and used a small spacer in between the hub adapter and the hub cover to keep the cover from rubbing against the column.
1973 Camaro RS
evilws6 is offline
post #6 of 7 (permalink) Old Sep 14th, 19, 8:36 PM
Hi, i’m currently having an issue i recently am trying to replace my old grant steering wheel for my 68 camaro and the issue i’m having is that the steering wheel adaptor hub is stuck and can’t seem to get it out i need anyone’s help i don’t want to damage anything !
crissxo is offline
post #7 of 7 (permalink) Old Sep 14th, 19, 10:56 PM
leo
this is an old post from 2015, but use the above method of a steering wheel puller and you should be fine. good luck!
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
