68 El Camino Bench Seat Question - Chevelle Tech
post #1 of 2 (permalink) Old Jan 30th, 15, 3:19 PM Thread Starter
I'm recovering the factory bench seat in my 68 El Camino. I removed the old seat back covers to find one of them had been home to a mouse nest at one time and some of the zig zag spring wire was corroded to the point of breakage. I turned to my pile of spare parts and a seat from a 72 El Camino. I removed the cover from the seat back of the 72 seat (which appeared dimensional identical to the 68 seat) to find it doesn't have zig zag springs at all, but a large foam pad that attaches to the seat frame.
My question is, if I used the seat frame from the 72 with this seat foam, will a correct appearing 68 cover like this fit ok over the 72 seat and foam?
I assume so, since the seats looked very similar externally other than the vinyl pattern, but I wanted to be certain before I placed an order.
turbo9 is offline
post #2 of 2 (permalink) Old Jan 30th, 15, 6:17 PM
Re: 68 El Camino Bench Seat Question
Another alternative is to just replace the zig zag springs. Upholstery shops may well have the raw spring material.
When I recovered the seat for my '68 I found a number of these springs busted. Rather than die a slow death by finding just one more busted part after business hours, I took it to a shop and had them install the new cover I had.
1968 El Camino, 402 with TKO
vrooom3440 is offline
This Thread is more than 1851 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
