1968 dash assembly parts - Chevelle Tech
post #1 of 1 (permalink) Old Oct 31st, 14, 6:05 PM Thread Starter
Ike
Our 68 didn't come with a dash bezel or instrument cluster.
Now putting the dash back together and cannot figure what part/nut
holds the cluster to the bezel.
The cluster package screws to the bezel from the rear with 3 screws
on the top, easy as there are holes for screws in the bezel, two from
the front bottom, also has screw holes and two from the rear bottom.
Here's where the problem is. The rear bottom on the bezel has a slotted
flat plastic piece 90 degrees to the cluster. The assembly instruction
manual, page 213, shows the screws being installed but not what they
screw into. Is there some type of 90 degree j-nut that clips to the plastic
slot on the bezel? If so any idea where to find such item?
Tnx
Ike
IkeI is offline
This Thread is more than 1984 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
