Dash Conversion from sweep to SS gauge package - Chevelle Tech
post #1 of 10 (permalink) Old Mar 28th, 14, 1:53 AM Thread Starter
Edwin
I was looking at Ground Up's volume 13B catalog and on page #139 they show a 1970-72 Super Sport dash kit. They say if I am converting from a sweep style dash they "have me covered" with the kit. I would like to go with the SS dash but do not want to get into a money pit with extra parts needed to complete the change-over.
Here's the question what hidden things should I look for, they want $1745 for the kit and it includes:
Dash Carrier with side vent assembles, dash lens, ash tray, glove box door, steering column cover, dash housing, steel backing panel, speedometer, tachometer, clock, temp/fuel gauge, instrument sockets, printed circuit board, OEM or modern ATO type dash harness with fuse box, and OEM forward lamp harness or engine harness.
I realize I'll have to buy sending units and little things like that but is there anything big?
Thanks,
1972 Chevelle Malibu 5.7
1970 Chevelle Nomad Straight six W/ 3 on the tree
1970 Camaro (now a RS)
2015 Silverado SLT 5.3
2015 Cadillac ATS Coupe
1965 Mercedes 190c
1996 Sea Ray 21' Signature Select 5.7
2013 Forest River T2050 Travel Trailer
sped01 is offline
post #2 of 10 (permalink) Old Mar 28th, 14, 9:35 AM
Re: Dash Conversion from sweep to SS gauge package
Are you working on a 72? If so does your present dash have the fasten seat belt light in the speedometer cluster? If so that kit will work, but will not be factory correct. All 72 Chevelles after, I believe it is January 1st had a fasten seat belt light. The reproduction dash housings do not have provisions for that and may not be correct for your car.
RealRed70 is offline
post #3 of 10 (permalink) Old Mar 28th, 14, 10:05 AM
http://desmoines.craigslist.org/pts/4394842878.html
Here's a dash with the fasten seat belt light.
70cko4sp is offline
post #4 of 10 (permalink) Old Mar 28th, 14, 10:12 AM
That one does not look too bad. Has two small holes in the face to the left of the radio. May have been from a CB mic. bracket. Needs a repaint and a re silver and there ya go.
post #5 of 10 (permalink) Old Mar 28th, 14, 10:22 AM
todd
Smokey and the Bandit chevelle? LOL
todztoyz is offline
post #6 of 10 (permalink) Old Mar 28th, 14, 10:27 AM
Sped01 I sent you a Private Message. I have a very nice original with everything you would need.
post #7 of 10 (permalink) Old Mar 28th, 14, 10:47 AM Thread Starter
Edwin
I believe it does have the seat belt light, although it does not light up. If that is the only issue then I am happy with that, it's not a real SS car but it wants to be.
1965 Mercedes 190c
sped01 is offline
post #8 of 10 (permalink) Old Mar 28th, 14, 12:01 PM
One thing to keep in mind. An original dash will hold its value and may even increase in value. When you buy an aftermarket kit, it will only decrease in value. Once you purchase them you can have a hard time getting half of your money back if you decided to sell it. That is because they are really no different than putting an aftermarket set of custom wheels on your car.
post #9 of 10 (permalink) Old Mar 28th, 14, 12:54 PM
zach
HI Jim. Is Ground up and OPG using same manufacture on this piece..?
Chevelle '71 is offline
post #10 of 10 (permalink) Old Mar 28th, 14, 2:30 PM
Go to http://hinshawschevelle.com/media/catalog.pdf and look at page 18. Great place to buy from and very helpful. Found me a couple parts not even in the calalog.
skongolf is offline
This Thread is more than 2196 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
