Door Panel How to - Page 4 - Chevelle Tech
post #46 of 54 (permalink) Old Oct 31st, 16, 9:46 PM
Re: Door Panel How to
Old thread but lots of good info. When I did my Nova the door was used to align everything. After removing the metal rail from the old panel it was cleaned with a wire wheel to remove the old glue. The clips were installed on the panel and the panel fastened to the door, aligned so it looked even all around. Marked the lower holes for the 4 screws and installed them and then placed the rail on the door and marked where it needed to be for a perfect fit. The actual assembly was done off the car just like Michael described but using clips to hold until the glue dried.
The manual locks were omitted for a cleaner look as were the power window and door lock switches. The window switches were in the center console and the door lock switch and trunk release were hidden in the ash tray.
RAMBO likes this.
63 Nova wagon
Philip is online now
post #47 of 54 (permalink) Old Nov 1st, 16, 4:34 PM
On a 68-72 Chevelle that white material does not wrap over to the backside as shown on the Nova panel. It get cut off at the back edge of the steel panel right before the small ridge. Just the vinyl would get wrapped around the back side of the steel panel.
RealRed70 is offline
post #48 of 54 (permalink) Old Nov 1st, 16, 8:58 PM
Thanks Dan, good to know. I have a set of unassembled panels coming this week.
63 Nova wagon
post #49 of 54 (permalink) Old Sep 9th, 17, 9:01 AM
is there an online supplier of trim panel clips shipping to the UK?
wheelspin is offline
post #50 of 54 (permalink) Old Sep 20th, 17, 2:24 PM
Found a good supplier based in the UK
https://www.greasemonkeydirect.com/c...ted-trim-clips
I know most of you guys are US based, but may be of help to UK members
post #51 of 54 (permalink) Old Apr 10th, 18, 6:06 PM
Great post! Does anyone know where i can get the metal caps for a 68 2 door sedan?
James
JamesPhelps is offline
post #52 of 54 (permalink) Old Jul 6th, 18, 3:01 PM
Hey anyone actually put sound deadener on the door panel itself? I was thinking of putting sound deadener on the inside of the door panel, to where I can still access the inside of the door when I take the panel off.
jake28050 is offline
post #53 of 54 (permalink) Old Jul 6th, 18, 8:19 PM
Just use the thin material.
You will still need a moisture barrier to keep water inside the door and off of the panel/interior.
http://www.dynamat.com/automotive-an...ion/superlite/
1953 Chevy Bel Air 4 door.
1968 Chevy C20 CST Longbed.
1967 Malibu 396 Powerglide.
Cal Malibu is offline
post #54 of 54 (permalink) Old Jul 26th, 18, 10:33 PM
It won't do any good on the door panel, it quiets the noise by reducing the vibration of the metal it is attached to.
63 Nova wagon
This Thread is more than 720 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
