Bench to Bucket Conversion Diagram - Page 5 - Chevelle Tech
 4Likes
Closed Thread
post #61 of 186 (permalink) Old Jun 5th, 09, 1:37 PM
Ken
Re: Bench to Bucket Conversion Diagram
Yes, 4-speed cars recieved a seprate hump. Everyone that sends a pic showing the measurment never shows the exact measurment or from where they measured? It has to be exact. Below is a pic of a 4-speed hump showing what you asked.
Owner 70 LS6 Clone Resto
crazychevelleman is offline
post #62 of 186 (permalink) Old Jun 5th, 09, 3:38 PM
Ken,
Is that from a 70-72 car?
The Buick from the same years had the opening more to the LH side & was a completely
different animal from what you've shown. I made contact with a Buick 4 speed guru I know. I'll let you know his reply. I'm sure he'll do anything in his power to help out another car nut.
Steve Craig
'71 Buick Skylark 350-4V
Steve Craig is offline
post #63 of 186 (permalink) Old Jun 5th, 09, 3:48 PM
Ken
70 Chevelle
post #64 of 186 (permalink) Old Jun 5th, 09, 4:08 PM
Ken,
Friend is familiar with the Buick 4 speeds only. Couple pics attached will show quite a difference. One is from a '69 GS400 showing floor pan & hump.70-72 are the same. Second is the consolette option around the shifter boot & a short storage console that goes between the bucket seats. I have a shorty storage console in my car. It's auto shift on the column with bucket seats. The centre portion of the consolette was available with factory tach., I don't believe the smaller guages are factory.
Linkages are likely also quite different as the mount to the LH side of the trans.. Chevelle linkages have an offset to them?
Name:	69_Buick_GS_400 (576 x 432).jpg
ID:	21346   Click image for larger version
Name:	cons (654 x 720).jpg
Steve Craig
post #65 of 186 (permalink) Old Jun 5th, 09, 4:51 PM
Ken
Ya, not even close
post #66 of 186 (permalink) Old Jun 5th, 09, 11:14 PM
Al
Ok, "Crazychevelleman" here we go again about my brackets being WRONG. I know they are not set up as someones diagram shows. The diagam was helpful though. The long bracket might be an inch back too far as well. But this is what worked for me! If I went as the diagram showed my seats rocked. This is what worked for me. Let me ask you a question. When I put my seats in, if they clear the seat belts, shifter column and slide back and forth is it still wrong???
Al
72 Chevelle SS Clone.
Engine, 350
12 Bolt Rear End
Eaton Posi 3.90 gears
Transmission 700R4 3000 stall
Work still in progress
Pics
Restoration website
shane918 is offline
post #67 of 186 (permalink) Old Jun 6th, 09, 10:04 AM
Ken
Sorry to offend you! Please, forgive me! However the Factory did not do it this way, it is wrong. But like you said, its working for you, but It don't mean its right.
Let me ask you a question that dont pertain to this. Say for instance a man works at a company and steals a little from them over a period of 20 years, The Lord said, "thou shalt not steal", and when he stands before the Lord he is rewarded acording to his work here! the reward for Sin is Death in hell, without Jesus christ's atoning sacrafice this man has no hope. It worked for him but it did not make it right.
See my point.
Your tracks
Here is what I think happend: Below is a pic of the seat tracks Note: (A) Is taller than (B) it is possiable to get this turned arround! By doing so, your seat would rock or wobble, you would have to use the Small Bracket at the rear of the mounting point Like you did! The way to tell is this: If you have the seat adjuster knob pointing toward the door on the outside of the seat, the 1 hole (Taller leg) should point to the front and mount to the one stud on the bracket. the 2 holes (Smaller leg) to the rear using the outer most hole. The inside track should be the same as the adjuster track. when you pull the leaver to adjust the seat, siting in the seat the Lever should pull foward not to the rear. This was designed to give the seat a slight recline. I think if you re-check you will find the problem, Just trying to help brother.
Original Track Location
[/QUOTE]
post #68 of 186 (permalink) Old Jun 6th, 09, 11:35 AM
Al
No, I don't see what your anlogy has to do at all with the subject?? But thanks for the help.
Al
Engine, 350
12 Bolt Rear End
Pics
Restoration website
shane918 is offline
post #69 of 186 (permalink) Old Jun 6th, 09, 11:57 AM
Al,
Have a look at the Buick site referred to earlier. In it you will find a number of floor pan photos from a factory bucket seat car. I converted my own & have also "been there - done that".
One thing to remember is that the rear outboard mount- hole in the floor - gets re used.This is a common anchor for both bench & buckets. My sketch is at the end & it may help in positioning the brackets before they get welded down.
Steve Craig
post #70 of 186 (permalink) Old Jun 6th, 09, 12:02 PM
Al
Really?
It make sense to me.
There has to be a reason why installing the brackets in their proper place cause the seats to rock otherwise everybody would have rocking seats.
post #71 of 186 (permalink) Old Jun 7th, 09, 2:15 PM
Al
Really? See you guys don't understand that I could give a damm if the set up is right or wrong. Your "right way" did not work for me, my wrong way did
Engine, 350
12 Bolt Rear End
Pics
Restoration website
shane918 is offline
post #72 of 186 (permalink) Old Jun 7th, 09, 2:27 PM
Send a message via AIM to 69 Daytona Yellow 3 Speed
Wow...
33 Years of ownership, thanks dad !
Im real, my car is real and i have a tag line i dont hide nothing.
My 1969 Mellow Daytona Yellow SS396, 3 Speed, Bench Seat, Original Paint "Survivor".
Press 1 for English
Press 2 for Deportation
69 Daytona Yellow 3 Speed is offline
post #73 of 186 (permalink) Old Jun 7th, 09, 10:36 PM
If you don't want it done right, that's cool, what ever works for you, it's your car.
You could or you couldn't give a damn?
post #74 of 186 (permalink) Old Jul 3rd, 09, 5:45 PM
here is a link to seat brackets. I havent tried them so I don't know if this would be pertinent to anyone or not.
http://www.carpartsdiscount.com/auto...html?3593=4554
Berto is offline
post #75 of 186 (permalink) Old Sep 15th, 09, 8:45 PM
I installed my buckets today after removing the old bench seat.
I took a number of images that may help out other is the conversion bracket placement.
The seats are from a 68 Buick Skylark, they will need recovering and restored but wanted to get things in place.
Here's a link to the installation pictures
jeffafd is offline
Closed Thread
This Thread is more than 1592 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
