Bench to Bucket Conversion Diagram - Page 13 - Chevelle Tech
 4Likes
Closed Thread
post #181 of 186 (permalink) Old Aug 31st, 14, 5:15 PM
Doug
Re: Bench to Bucket Conversion Diagram
I used the three (3) piece kit and the outboard rear hole as Mike mentioned. Worked great. Could have been a bit overkill, but I mounted the brackets to the rails and my bucket frames for the mock up to make sure everything was square to the car and to the adjacent seat. Worked great...
1972malibu is offline
post #182 of 186 (permalink) Old Aug 31st, 14, 7:56 PM
I never heard of a three piece kit. How does that work? It should be a four piece kit, or a generic two piece kit.
RealRed70 is offline
post #183 of 186 (permalink) Old Aug 31st, 14, 10:10 PM
Doug
Dan,
You are right… Total laps in memory. I was thinking the front mounting brackets were separate, but the inner piece was in-fact a single long strip that captured both ends of the rail.
They say memory is the second thing to go…
post #184 of 186 (permalink) Old Mar 5th, 16, 6:59 PM
Todd
The pictures are no longer visible. Can someone provide the measurements on where the seats go? Has anyone fabricated their own brackets or does everyone buy the ones that are sold by the vendors?
72 Chevelle
70 Nova 540 ,powerglide SOLD
67 El Camino
Tod74 is offline
post #185 of 186 (permalink) Old Mar 5th, 16, 7:20 PM
http://www.72malibu.chambersohana.co...ts_install.pdf
post #186 of 186 (permalink) Old Mar 6th, 16, 1:42 PM
Doug
Thanks Dean. I didn't realize anyone was still using those links.
There is also a console installation pdf if anyone needs it.
http://www.72malibu.chambersohana.co...le_install.pdf
Here was the console and seat mock-up.
The mostly finished product from the maiden show a couple of years ago.
-Doug
Closed Thread
This Thread is more than 1592 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
