Headliner install write-up - Page 18 - Chevelle Tech
 18Likes
post #256 of 280 (permalink) Old Aug 7th, 16, 11:31 PM
Re: Headliner install write-up
I'm doing the HL in my 72. There's quite a bit of glue residue on the 'tac strips' from the factory. These strips are only held in with screws. I'm wondering if I can remove these to clean up or how have you guys done / used to get the old glue off? I've read every post I this thread, saw about every video made on bow style headliner installation..... Taking my time, and finally attempting it.
Thanks in advance!
BB72Chevelle is offline
post #257 of 280 (permalink) Old Sep 5th, 16, 10:21 AM
Charlie
I took them all down and numbered them as I went around the car, and also numbered the framework for the roof above them, so I'd know where they went upon reassembly. Then I chucked a wire brush wheel in my drill press-( a hand drill works too, just harder to manage)
Basically I took off most of the dried up glue, but it wasn't perfect.
Charlie
1970 Chevelle Malibu/SS Tribute
Cortez Silver, 355 SBC, 200 4r
1967 Camaro RS (basketcase project)
1984 F-150 parts hauler
2011 Chevy Malibu LTZ Granite Black daily driver
vetteman_72 is offline
post #258 of 280 (permalink) Old Sep 7th, 16, 10:41 AM
Shane
How are you doing with this?
fishhead is online now
post #259 of 280 (permalink) Old Feb 9th, 17, 6:06 PM
Ok I have my new legendary headliner up with bows and clips in place (no glue yet) on my 70. I just can't seem to get it as tight as I would like it. Should I worry about that or will it tighten up a lot when it gets hot. My garage is only 65 degrees right now and I have read some people recommend to heat the interior/headliner while stretching it into place. I assumed the headliner will shrink when it gets hot but maybe not.
Mark
1970 Chevelle SS, Black
1970SS is offline
post #260 of 280 (permalink) Old Feb 9th, 17, 7:04 PM
Did you mean shrink when it gets cold? I don't know if any material will shrink when it gets hot.
I don't know if this will help or not, but I put a ceramic space heater inside my trunk as I was prepping the car for paint. i brought the metal up to 80 deg on a 50 deg day. Also, Harbor Freight makes a 12V defroster, you can pop that in there and let it run for a few hours on a 12v supply and have the car all closed up. A few hours should give you the answer. Your own def could work too, but that would require a running engine.
KarlJay is offline
post #261 of 280 (permalink) Old Feb 10th, 17, 3:53 PM
I thought the same thing. Most material expands as it gets hot and contracts when it gets cold. However I watched some headliner installations where they were using a heat gun to get the wrinkles out so that tells me the heat is shrinking the material.
Mark
1970SS is offline
post #262 of 280 (permalink) Old Feb 10th, 17, 4:49 PM
Rich
Or maybe it is just relaxing the material allowing the wrinkles to flatten out...like a steamer does for clothes.
fishhead likes this.
Rich
1967 El Camino (White)
1965 El Camino (Sold that junk)
HandOverFist is offline
post #263 of 280 (permalink) Old Mar 19th, 17, 7:08 PM
Randy
Great write up! Thanks for taking the time.
rattracer is offline
post #264 of 280 (permalink) Old May 15th, 17, 3:05 PM
Finishing up my 70 today. Ill post pics later. tips my 70 Chevelle is totally different then my 69 Camaro that took 4 hors start to total finish. all day on the 70 no where near done. Yes remove all those metal clips along all edges and scotch brite them and clean off all old glue. Then re install. I laid mine out for a week on the dinning room table, then for 2 days on a flat table in my garage and still needed a steamer and a heat gun. There were no clips with the sail panel from PMI so we are trying glue and wrapping edges. Ill finish the story tomorrow with more info.
rufcar is offline
post #265 of 280 (permalink) Old May 16th, 17, 6:26 PM
Discovered I needed 2 vertical rubber interior weather strips just in front of the sail panels. NO one offers them as part of there kits? Interior is almost done. I need to install those 2 rubbers 1st then reattach the rubber covered steel windlace on those curved edges. Rear seat cardboard some insulation the 2 plastic bottom arm rest fillers and seat back and bottom. Then shes 100%. Pics soon.
rufcar is offline
post #266 of 280 (permalink) Old Jun 13th, 17, 12:18 AM
This has inspired me to do it myself. Since it is a wagon it is about twice the size of a 2 door car. At least I will not have the sail panel area to deal with Have not removed it from the box yet, is there a front and rear edge to the headliner? Need to get this in so the glass can be installed.
71350SS likes this.
63 Nova wagon
Philip is online now
post #267 of 280 (permalink) Old Jun 13th, 17, 2:18 AM
Ben
usually you can tell the front from the back by the spacing of the bows. the ones in the front are usually farther apart than the rear... but of course not sure in a wagon.
PUI headliners they usually mark the centerline and mark the front.
Ben R.
RAMBO is offline
post #268 of 280 (permalink) Old Jun 13th, 17, 9:16 AM
Thanks, it is a PUI headliner.
63 Nova wagon
post #269 of 280 (permalink) Old Jun 13th, 17, 1:07 PM
Ben
I think the most important thing you can do is to spread it out and heat it up ahead of time to eliminate the folds & creases.
Normally i like to put them in the clothes dryer on hot for about 5 mins... but with one that big i'm not sure. Might still be worth a shot. Those creases are a PAIN to work out later if you don't get them out first.
If you have a clothes steamer that can also work well to heat it up. Makr yourself a little a-frame to support and spread out the material, then steam the creases from the back side.
Ben R.
RAMBO is offline
post #270 of 280 (permalink) Old Jun 13th, 17, 1:57 PM
Bart
I will be installing mine here in the next week. I am finishing up on some minor body work. I got most of the wrinkles out of mine by going ahead and installing the bows, trimming the bow sleeves back enough to pull it fairly tight, then put several of the clips on to hold it. It has been that way for about 3 months now and all of the creases/wrinkles are gone. I do have the luxury of it just sitting in the garage without the glass in it. I will pull it back out before i finish the paint next week and reinstall/glue everything before setting the glass. I am using the landau top HHR glue on mine. I have used it on dash pad vinyl etc and it work MUCH better than any of the aerosol products hands down. I also have an upholstery steamer that I used when I made my new seat upholstery in order to fine tune the area above the sail panels.
Bart_Swisher is offline
This Thread is more than 653 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Headliner Install ELLI Interiors 13 Dec 3rd, 16 6:11 PM
70 headliner bow rods jay70 Interiors 1 Jan 23rd, 06 9:26 PM
76 Nova headliner trouble. Need ideas ? Mr69 Interiors 18 Aug 14th, 05 1:37 PM
HEADLINER HELP IN IL. Robert G Interiors 9 Jul 25th, 04 3:33 PM
Headliner Help/ Custom Install Idea feedphillipnow Interiors 4 Apr 23rd, 04 5:15 PM
