6 x 9 in package tray - Chevelle Tech
post #1 of 4 (permalink) Old Mar 5th, 06, 9:13 PM Thread Starter
i have a set of pioneer 6 x 9's that i want to put in the "package tray" of my 70 chevelle. there's nothing there now but some vinyl probably with some board under it. what do i need to do to be able to put the speakers in. thanks(new at this)
the ss kid is offline
post #2 of 4 (permalink) Old Mar 6th, 06, 2:38 PM
Re: 6 x 9 in package tray
If you look under the panel in the trunk you will be able to see if the metal is cut out for the 6x9s. You have a couple of options here. You can use the same package tray and cut it out to fit the 6x9s and then use the grills with the speakers or you can buy a package tray that has the mesh in it where the speakers are and you won't need to use any grills and the package tray will still look flush with no speaker grills. You will also need to run some speaker wire from the radio back to the trunk for the speakers.
RUQKENF is offline
post #3 of 4 (permalink) Old Mar 7th, 06, 3:27 PM Thread Starter
the metal is still there when i look from my trunk. so ill probably just cut out both the metal and the package tray to fit....how much does a package tray with the mesh in it run incase i decide to go that route
post #4 of 4 (permalink) Old Mar 7th, 06, 3:31 PM
Around $25 with the jute backing.
BUDS1970 is offline
This Thread is more than 5136 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
