68 repop dashpad quality problem - Chevelle Tech
post #1 of 5 (permalink) Old Mar 1st, 06, 10:12 PM Thread Starter
Tonight I tried to install a new repop dashpad that I bought about five years ago.This darn thing is a major disappointment.Several of the studs are not the correct length or in the correct location.The vinyl looks gathered and pressed where the pad is curved.I have spent a couple hours grinding and drilling the dash frame and I still am not happy with the way it fits.Is this typical and to be expected?I wouldn't mind cutting my losses and getting a different one if someone has recently intalled one of better quality and would tell me where they got it.
thanks
68-bb is offline
post #2 of 5 (permalink) Old Mar 1st, 06, 11:08 PM
Re: 68 repop dashpad quality problem
Welcome to repro world. Your worst nightmare..
I'd look for a good used one. I'd start with Ebay and then contact used Chevelle parts dealers. It shouldn't be difficult finding a good one.
Bill Rose is offline
post #3 of 5 (permalink) Old Mar 2nd, 06, 11:44 AM Thread Starter
thanks Bill,
Mine needs to be blue so I may have a hard time finding a nice one.I was curious if anyone else has installed a repro recently and could comment on the quality.Maybe some other source of new could be better that what I have?
thanks
68-bb is offline
post #4 of 5 (permalink) Old Mar 2nd, 06, 12:35 PM
You can try a different vender, but my guess is they all come from one manufacturer. So where you buy it wouldn't make any difference. You could also find a good used one and dye it. I've never dyed one, but I've seen several pads dyed different colors and they look fine.
post #5 of 5 (permalink) Old Mar 4th, 06, 6:34 AM
Mark
I"ve run into this problem before... couple of tricks that may or may not work... the studs on the back that don't line up correctly... cut off & reepoxy them into the right spots .. it allso helps to let the pad sit in sun warmed area to make it more supple,,, if all of above don't work ... theres always buying another one stock oem & sending it out to be recovered ... best wish's & keep telling your self its only a car part... while trying your best not to fling it across the rooom !!!
"An expert is someone who has made every possible mistake within a very narrow field"
68KMENO is offline
This Thread is more than 5151 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
