Recovering '70 SS Bucket Seats - Page 4 - Chevelle Tech
 5Likes
post #46 of 105 (permalink) Old Sep 26th, 07, 8:39 AM
Shane
Re: Recovering '70 SS Bucket Seats
One trick I use...
I grab a really good wrie hanger. I cut about a 6-8 inch piece from it. I use that for the hard to pull places. I use the hanger to pull the pieces together then when they are close enough I grab the hog ring and pliers and squeeze them together.
If your going to use zip ties you need to get really good qualtiy ones that are fairly thick and wont break or let go. Used zips in a FIAT I had once and they let go after a few months.
fishhead is offline
post #47 of 105 (permalink) Old Oct 22nd, 07, 4:48 PM
I am also recovering a set of 70 Chevelle Buckets and the doner buckets came from a 1970 Monte Carlo. My issue is that the seat covers I am removing did not have the 70 emblems so I need the location of the emblems for the replacement seat covers. Can somebody help me out with the dimensions for emblem placement?
Thanks,
Bigbowties
Bigbowties is offline
post #48 of 105 (permalink) Old Oct 23rd, 07, 8:09 AM
Ben, PUI and Distinctive are not the only companies making these interiors, we not only make them but, we make the highest quality interiors available and offer a Lifetime Warranty with them!! The best foam kit available is made by American Cushion Industries which we offer along with our seat covers. Thanks. Eric @ Legendary Auto Interiors, Ltd.
lail1985 is offline
post #49 of 105 (permalink) Old Dec 12th, 07, 10:25 AM
Thanks,
Bigbowties
If you measure from the top seam (the one that would be barely covered by the headrest) to top of the emblem it is 6"
mr 4 speed is offline
post #50 of 105 (permalink) Old Dec 26th, 07, 8:54 AM
i had mine done he has done many seat covers for older chevelle's camero's novas he was good.
70 sprayed Chevelle
GotSpray is offline
post #51 of 105 (permalink) Old Jan 9th, 08, 8:09 PM
Send a message via AIM to FlameOut
I can vouch for that. Received my covers and they look great! I still haven't installed them, and can't wait to. Hopefully I can find someone local that sells the hog ring pliers and rings
396 (402) .030" over
Edelbrock
Performer RPM Air Gap
Lunati 60203 / KB 0.180
domed pistons
Holley Street Avenger 770
Muncie M-22
12 bolt posi 3.31
FlameOut is offline
post #52 of 105 (permalink) Old Jan 14th, 08, 8:31 PM
bobbyo
Just so ya know I just had mine redone (just new foam) reused the covers they were in great shape. 126$ that included tax. I bought the pre shaped foam from OPGI. It came out ok. Only had to do the drivers side. Didn't ever sit in the passengers seat (only had it since Sept 1st) and put it away in early November. Good luck!
"The meek shall inherit nothing".... FZ
gatorbob is offline
post #53 of 105 (permalink) Old Mar 12th, 08, 2:32 PM
i tossed my seat covers, one piece at time as i required it, into a pillow case & tossed into the clothes dryer for a vert few minutes to remove the wrinkles.
861_ford is offline
post #54 of 105 (permalink) Old Jul 21st, 08, 4:20 PM
Charlie
I just recovered my 70 buckets and yes it's a job but if you take your time they will turn out OK. I wished I would have known about the trash bags also, as it’s very hard to pull the material over the foam. I learned that if I put on the bottom of the back bucket first its worked better than putting on the top and trying to pull on the bottom. The only problem I encountered was with the back cover for the bucket seat. I purchased my seat covers through Original Parts Group who gets them from Distinctive Industries. I found that the bottom flap of material (the flap that you pull up to the frame and covers the springs) was too short. I could not pull it up to the frame and hog tie it as it was about 4 inches short. I measured the flap from the support seam to the edge and it was about 4 inches. I needed twice that, so I measured off the original seat cover and the flap measured about 8 inches. I called Original Parts Group to let them know that the pattern was wrong and did not get any sympathy or response. So, I took the two back covers to my local upholstery shop and for $20 he sowed in new flaps which worked out fine in the end. The other thing I could mention to you is the foam pads. For me they were too thick in the middle for the buckets and cause a hump in the back and bottom of the seat. This was uncomfortable to seat in as you felt like you had something pushing you in the middle of your back and up your rear end. So I used a sanding disc on my angle grinder to reshape the foam to get it more concave than convex. Good luck…
Charlie70SS is offline
post #55 of 105 (permalink) Old Aug 28th, 08, 2:48 AM
The best cushions are the ones made by American Cushion Industries (made in the U.S.A. too), the foam is the right size & so is the density, plus you get a limited lifetime guarantee if you are the original purchaser. They might be a little more money, but ACI cushions aren't those low quality, hard Chinese made knock offs that PUI offers, or the oversized, hard as a rock cushions that OPG sells. You can get ACI cushions at places like Legendary & NPD.
ElectricCentaur is offline
post #56 of 105 (permalink) Old Oct 6th, 08, 4:24 AM
Send a message via AIM to Malibulvr Send a message via Yahoo to Malibulvr
Not trying to be a dick but do we need the advertisements??? WE get it, you have great seats, go to the classified section!
Thanks,
Malibulvr is offline
post #57 of 105 (permalink) Old Nov 12th, 08, 3:08 AM
I have a rare STRATO BENCH SEAT, Bucket seat backs with a bench seat bottom and a armrest in the middle. (this is not a bench seat like an olds with armrest ) It has 70-72 backs with headrest and button in the upper back of seat . How do i get the backs off of the seats without breaking the backs ? Not sure how the buttons come out or apart to get the backs off. I have to buy a set of bucket seat covers and a set for bench to recover this seat. Got lucky and found foam for top bucket seat portion separately on ebay now i have to buy a bench foam set to get the bottom part. I have seat upolstery for a 70 buick skylarkwith armrest new in box but not sure if i will catch hell for putting the skylark upolstery in the chevelle. It is alot nicer cover pattern than the 70 chevelle pattern. i also have another bench and back seat and just might build two sets of seats for the car. The BENCH/BUCKET would be vey comfortable in the chevelle. It came from a 69 Caprice 427 car and is same width. Just need to know how to remove the buttons or the backs. I know you guys are smart ! YOU DRIVE CHEVYS !
MYOTRUCK is offline
post #58 of 105 (permalink) Old Apr 4th, 09, 9:56 PM
Ken
If you need bottom or back spring sets (my driver's side was all broken and bent up) Muscle Factory has 'em w/side springs very reasonable!! Mine are on their way!!
kendaddy853 is offline
post #59 of 105 (permalink) Old Apr 12th, 09, 8:42 PM
Ken
Quick-Update--With new springs on bottom and back-and new foam-and new pui covers-This was like stuffing an elephant into a suitcase!! Had my better half help or this wouldn't have worked out!! Looks Fantastic (showroom puffy and sweet) but with quite a bit of effort!! You'll definately need extra set of hands!
post #60 of 105 (permalink) Old Apr 13th, 09, 8:04 AM
Hank
Installed a new bottom spring set from NPD on Saturday. Used the old foam, it was actually in very good shape. I turned the seat upside down on the floor to hog ring around the bottom. You can push, lean, or sit on the seat to collapse the springs some. Then you'll have enough material to wrap around and hog ring in place.
Hank
Finally is offline
This Thread is more than 1591 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
