Speedometer Cable Question - Chevelle Tech
  • 1 Post By jim3
post #1 of 10 (permalink) Old Mar 24th, 20, 5:00 PM Thread Starter
I have the speedometer cable out of the car and I want to clean/lube it before it's reinstalled. I used a pair of pliers and pulled pretty hard but the cable wouldn't come out of the outer tube. Is there a trick to separating the two.
Thanks, Chris
1970 SS396 Chevelle
468 ci, TH 400, 3:73 posi
SS468 is online now
post #2 of 10 (permalink) Old Mar 24th, 20, 5:58 PM
Hank
Re: Speedometer Cable Question
Did you try pulling it out from both ends.
HKalin is offline
post #3 of 10 (permalink) Old Mar 24th, 20, 6:48 PM Thread Starter
Just tried pulling on the speedometer end. Everything I read said it comes out on that end.
1970 SS396 Chevelle
SS468 is online now
post #4 of 10 (permalink) Old Mar 24th, 20, 6:53 PM
Jon N.
Buy a new one. Your old one is not worth the grief.
Jon N.
dyno jonn is offline
post #5 of 10 (permalink) Old Mar 25th, 20, 3:01 PM Thread Starter
Got it out. Soaked it in PB Blaster for a while.
1970 SS396 Chevelle
SS468 is online now
post #6 of 10 (permalink) Old Mar 27th, 20, 8:38 AM
Soak the cable housing and flush it out several times with carb cleaner, you will be surprised at the gunk that comes out,
1953 Chevy Bel Air 4 door.
1968 Chevy C20 CST Longbed.
1967 Malibu 396 Powerglide.
Cal Malibu is offline
post #7 of 10 (permalink) Old Mar 27th, 20, 11:10 AM Thread Starter
Thx everyone for the advice.
When I reinstall the cable, is there a trick to be sure I engage the cable correctly into the back of the speedometer?
Thx, Chris
1970 SS396 Chevelle
SS468 is online now
post #8 of 10 (permalink) Old Apr 3rd, 20, 3:29 PM
Don't know that I'd call it a trick, just make sure the inner cable is inserted into the speedo head before screwing on the connector.
To prevent speedo cable noise while driving, I've had good luck with PB product Graphite Dry Lubricant. None of my local auto parts stores had it in stock but HD had it on the shelf.
Not2Fast likes this.
jim3 is offline
post #9 of 10 (permalink) Old Apr 4th, 20, 10:50 AM Thread Starter
Thx Jim3. I didn't think the speedometer end of the cable had a threaded connector. I thought the retainer on the back of the cluster held that end in place and the threaded connector goes to the tranny.
1970 SS396 Chevelle
SS468 is online now
post #10 of 10 (permalink) Old Apr 5th, 20, 4:52 PM
My trick was to connect the speedometer end first. When you insert the cable, spin the transmission end to ensure it moves. It also gives you a little more slack to work with.
70 El Camino SS 396
68 GTO (Thanks Mom)
06 Silverado
07 SRX
OO52 is offline
